Timing chain tensioner help
BIGBALDGUY
I'm rebuilding a 3000 engine for a friend and having trouble finding information. I bought the service manual on a cd but can't get it to open, I hope someone here can help me. I see the timing chain tensioner is oil pressurized but also has a manual adjustment. Anybody know how to do the initial adjustment? I also need the torque spec for the cam nut. I'm sure I will have more questions later, thanks for any help.
steveg
This is more of a manual-type question, as a detailed explanation is needed.
Manuals are available used or new on eBay or Amazon.
B
BIGBALDGUY
Thanks for the reply. I've already spent money for the service manual disc, that I can't get to work. I'm far enough along with this build that if someone can help me out with the tensioner adjustment and the cam nut torque I can finish this project.
John_Progess
On the back of the tensioner body or directly opposite of the rubber slipper pad there is a small hex head plug with a lock tab washer. If you are removing the chain tensioner, with the plug out you need to insert a 1/8" allen wrench and turn the wrench clockwise, as viewed from the opposite end of the rubber pad, untill the rubber pad is free from spring pressure. If you are installing the tensioner, you release the tensioner for operation by inserting the allen wrench and truning it in an anti-clockwise direction as far as possible and push up on the slipper pad with your finger to engage the chain. If you look at the end of the rubber slipper pad you will see the allen hole and notice a helical groove in the slipper pad shaft with notches in the groove. These notches prevent the slipper pad from releasing tension during operation and are there to account for chain/pad wear. Hope this helps and have a good day!
John
B
BIGBALDGUY
Thank you! That helped a ton! Just by looking at the tensioner I figured out how it works but wasn't sure of the initial adjustment. By any chance would you have the cam nut torque spec? Thanks again!
EV2239
The manual is misleading. Take the plug out of the bottom, insert the Allen key and rotate it while pressing the plunger/damper pad into the housing. Hold it in and mount the assembly onto the front plate and screw in the two retaining bolts. Once you're sure it won't fly apart, release the plunger and let it press against the chain. Now tighten everything and replace the bottom plug and tab washer.
Healey Nut
It's not an adjuster , think of it as a no tension lock to allow assembly which once you have stuff assembled you release the lock to allow the spring pressure to do the initial tension and the oil pressure takes over once she's running .
BoyRacer
Cam nut torque spec? There is nothing in the books that I know of. I have always just tightened it up. Never used a torque wrench. Just thinking about it now i would say that I probably used something like 50 to 55 lbs of torque. There is no force pulling the cam sprocket off the cam so no need to go overboard with torque. In fact it is just the opposite... the cam is being pushed forward into the cam thrust plate which has no effect on the sprocket. Plus there is the tab washer to keep the nut from turning after it is tightened.
B
BIGBALDGUY
Thanks for the info. On the opposite side of the tensioner there is a rubber faced guide for the chain. After I put the timing set on I noticed the side of the links are very close to hitting that guide where it bolts to the front plate. I don't see any way to gain clearance, it's just a "bolt on and go". Am I missing something?
vette
I think you are now asking about the timing chain vibration dampener fitted to the 6 cylinder engines. Here's a pic, ... I hope.
Patrick67BJ8
That's the piece. The side of the chain passes VERY close to where it bolts to the front plate.
there was problems with some aftermarket ones delaminating a few years ago. I think Denis Welch in the UK makes a high performance one. Somebody will chime in?
busybrit
The early engines didn't have the extra guide as its called. Also, you need to fit two paper gaskets each side of the metal plate that the tensioner is connected to. This will prevent an oil leak prior to the oil reaching the rubber tensioner block. I know this cos I did it today.
Also turn the engine over by hand prior to fitting the timing cover, then again with the timing cover fitted to determine that there's no difference.
I've had the pulley surface bind up on the inner steel lip, just behind the front oil seal due to a distorted timing cover.
Johnb
Goldie
There is a YouTube video about the chain tensioner on the Moss Motors channel. I haven't looked at it in a while but it covers more than one style of tensioner.
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
D TR2/3/3A Timing chain tensioner. Triumph 3
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
Darrell_Walker Timing chain tensioner wear Triumph 8
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
H 100 Engine Timing Chain Tensioner Austin Healey 3
John Loftus Timing chain tensioner question Austin Healey 14
P Newbie Missing or Broken Timing Chain Tensioner? Triumph 11
michalotti_tr TRactor motor timing chain tensioner Triumph 7
A Timing chain tensioner---old or new?? Triumph 4
Y Timing chain tensioner spring Triumph 2
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B TR2/3/3A Timing chain cover goop location Triumph 4
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
