Timing Chain - Slackend
gonzo
Now with the crankshaft nut, pulley and timing cover removed, the timing chain mechanism to this AH 3000 BJ-7 could be assessed. The Timing Chain Tensioner is riding up aginst the chain and chain is taunt -this is good. However, there's some chain slacking on the opposite side nearest the Dampner. Just how much chain deflection is allowed on the Dampner side? Deflection is about 1/2 to 3/4 inch.
Engine was running great prior to demantle; there's no deviation on timing.
Is there some allowable timing chain deflection or slack on the dampner side or should it be tight. Took some pics but first I need to learn how to post them.
Thanks, GONZO
Brinkerhoff
The cam timing will retard as the chain stretches, so a gradual loss of performance over the life of the engine. You would need a dial gauge to measure it. Usually the engine performance drops gradually enough that you wouldn't know it. You do run the risk of the tensioner foot coming of the housing and wedging into the chain perhaps causing a catastrophic failure. I've seen the chain stretch that far but not break.
G
gonzo
Jumped to conclusions on condition of timing chain. Turned engine in direction of rotation and timing chain tighten up. No slack. Removed original TC tensioner and although the elastomer, bumper, portion is in excellent shape, the shaft is worn. The tension body seems to be in good shape too. The original 50+ year old tensioner will be replaced with a Moss ROLO unit. And although they function in much the same way, I prefer the original's design and look.
Thinking of taking the original TC tensioner to a specialty automotive machine shop to see if it's restorable.
BTW, bolt-heads for the tensioner are safety wire prepared but they also have locktabs - sort of a belt and suspenders set-up. Not skilled at safety wiring, so the labtab with be used.
GONZO
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B TR2/3/3A Timing chain cover goop location Triumph 4
B Timing chain tensioner help Austin Healey 15
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
Darrell_Walker Timing chain tensioner wear Triumph 8
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
M TR4/4A tr4A timing chain procedure? Triumph 9
c5racer 1500 Timing Chain Upgrade to TR6 Spridgets 1
W TR6 TR6 Timing chain oil seal question Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
doughairfield Timing chain sprocket to camshaft Triumph 9
T TR2/3/3A tr3 timing chain question [master link] Triumph 2
