1500 Timing Chain Upgrade to TR6
c5racer
Member
I'm looking to upgrade to the dual row TR6 timing chain and gears. My question is which Timing Chain Tensioner did you use, the TR250-TR6 or the Spitfire/Midget, GT6?
I used duplex TR6 vernier timing gear sets in 1500 before, and just used the same tensioner.
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
J oil leak at timing chain cover 1500 Spridgets 2
R timing difference for 1500 for different years? Spridgets 5
tosoutherncars 1500 DGV - timing Spridgets 12
J Timing a MG 1500 with modifications Spridgets 7
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
tosoutherncars 1500 Fireball & timing woes [continued] Spridgets 16
Morris Spitfire Spitfire 1500 Cam timing Triumph 2
L Spitfire Ignition Timing for my Spit 1500... Triumph 12
Morris 1500 Timing Curve Spridgets 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
