TR6 TR6 Timing chain oil seal question
Wilky
Hello again boys,
I hope that your Triumphs are coming along nicely and that your problems are small.
Well, I have Done the front wheel bearings and the results are good, the Wiki on this subject was very helpful so thank you to the man who wrote that!!
Whilst sweating and toiling during the above task I noticed that an oil seal has gone somewhere around the area that the pulley for the alternator and fan appear out of the timing chain cover. Is this a common thing and is it simply a case of removing the radiator / pulleys / timing chain cover and replacing a seal or does the experience on the forum think it could be something else??
I myself think it could just be the seal where it all comes out the timing chain cover, however I just need a bit or reassurance and someone to say "Yes, I've had that on my car!" Before I start tearing it all apart.
Any advice is greatly appreciated!!
Callum
AltaKnight
Oil leaks are notoriously hard to pinpoint because the fluid can seep a long way from where you actually observe it.
However, the bottom 2 or 3 bolts on the timing cover and the front 3 or 4 bolts of the oil sump all bolt into a solid bar of aluminium at the fron of the engine, because it is soft metal the average ham-fisted mechanic over torques the bolts and strip the threads in the bar. this inevitably leads to oil weepage and leaks in that area; A solid steel replacement is available.
Having said all that, all these cars leak oil and I wouldn't worry about it unless it's leaking badly because there's more work getting to this area than one imagines.
BobbyD
AltaKnight said:
............. all bolt into a solid bar of aluminium at the fron of the engine, because it is soft metal the average ham-fisted mechanic over torques the bolts and strip the threads in the bar. this inevitably leads to oil weepage and leaks in that area; A solid steel replacement is available.
The steel saddle block solves the stripping problem just like Patton's TA repair Kit solves the studs in the TA from stripping. Steel is good :yesnod:
c5racer 1500 Timing Chain Upgrade to TR6 Spridgets 1
bash TR6 TR6 timing chain sprocket alignment Triumph 3
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
sundown TR6 1973 TR6 timing light Triumph 3
floyd TR6 timing 75 tr6 Triumph 6
W TR6 Timing Light TR6 Triumph 1
Scott_Hower TR6 TR6 crank/timing gear quality issue? Triumph 2
J TR6 tr6 timing cover removal Triumph 3
TR3TR6 TR6 TR6 Timing issues Triumph 54
wangdango TR6 TR6 timing questions??? Triumph 5
wangdango TR6 76 TR6 timing questions Triumph 1
7 TR6 Timing the 72 TR6? Triumph 4
E TR6 TR6 Timing Triumph 27
veale001 TR6 TR6 TIMING QUESTION............................... Triumph 35
I TR6 TR6 timing help Triumph 8
B TR6 TR6 Camshaft Timing Triumph 4
E TR6 TR6 Timing Cover Fasteners Triumph 7
S TR6 Ignition timing on TR6 Triumph 3
R TR6 Ignition timing on '72 TR6 Triumph 14
E TR6 TR6 Timing Cover Seal Triumph 7
E TR6 TR6 Timing cover removal Triumph 10
Webb TR6 TR6: Intake Vacuum & Timing Triumph 15
I TR6 Ignitions timing specs for 69 TR6 Triumph 13
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
T TR6 Does your TR6 have timing degree marks Triumph 21
hondo402000 TR6 TR6 timing cover seal and gasket fix Triumph 7
A TR6 TR6 Timing cover miss-alignment???? Triumph 10
SCguy TR6 Ignition Timing with a timing light on a a TR6 Triumph 16
Cain TR6 TR6 Crank Turning for Timing/Retard Unit Triumph 8
AltaKnight TR6 TR6 ignition timing Triumph 6
H TR6 TR6 Timing- Need help please Triumph 2
H TR6 TR6 Camshaft timing Triumph 2
S TR6 TR6 Timing Adjustment Triumph 4
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
