TR6 TR6 crank/timing gear quality issue?
Scott_Hower
So I bought a crank gear from a supplier I'd never used before. The box says it's made by Arrow/Aeco. It doesn't want to slide on the crank snout. I MICd it and it's close, but maybe .001 too small. It goes on about a half inch, then binds. Crank nose is smooth and burr free and so is the gear ID. The woodruff key doesn't seem to fit either, but that might be due to wear on the key shoulders. The vendor says it was made in the UK and is a quality part. Seems a bid dodgy to me.
Google search shows that a number of other suppliers stock a higher quality gear made in Germany by Swag. I'm guessing maybe there' a reason?
Anyone else have an issue with TR6 crank gears? Educate me. :smile:
Cain TR6 TR6 Crank Turning for Timing/Retard Unit Triumph 8
B TR6 Tightening crank pulley bolt on TR6 Triumph 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
G TR6 TR6 innner door release and window crank removal Triumph 5
davidk TR6 Information for front crank seal - TR6 Triumph 11
V TR6 TR6 Crank pully bolt removal Triumph 8
G TR6 Crank Bolt Torque Setting on Aluminum Flywheel-TR6 Triumph 17
W TR6 TR6 Crank oil seal sleeve Triumph 4
bobh GT6 GT6 Crank in a TR6 Block Triumph 4
R6MGS TR6 TR6 Window Crank Triumph 6
Hawk813 TR6 TR6 Brakes Triumph 2
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
