TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^%
karls59tr
Bronze
Just replaced the fan ,rad and apron after installing new speedi sleeve,cover seal and gasket only to find the leak was really coming from a crack in the vicinity of the timing chain tensioner. I remember replaciing a timing cover many years ago because the tensioner had worn thru the cover. guess it happened again. I have a spare cover but I'll have to pull everything apart all over again :-(. I suppose it might be possible to sand down the leaking area and apply epoxy steel compound but it looks like there is a kind of bump where the leak is so there might be another issue with the tensioner or support pin that I should really investigate. Anybody else had this problem in the past?
JPSmit
I feel your pain but somehow you have ended up posting on the Spridget forum, when, judging by the heading you seem to want the Triumph forum.
good luck!
TR4nut
I had a broken tensioner wear through the cover as well. I would only consider getting it welded for repair options - too much headache to pull as you unfortunately know. Sorry!
K
karls59tr
Bronze
Re: Timing Chain Cover Crack TR3..Update
I decided to try patching the crack in the cover.I sanded down the bad area with some medium sandpaper. Next I cleaned the surface with brake cleaner. I applied JB Weld in stick form. It's a 2part epoxy putty that you knead into a patch. Let it sit overnight. No more leak. I'll keep an eye on it to see if it holds and do a proper replacement in the winter.
CJD
Well, I hope it works...but wouldn't get my hopes up too much. If it wore through the steel, I don't think the epoxy will last too terribly long. But, who knows!
John
TomMull
Did a temporary repair like that on my old JD track loader transmission. Dropped a nut inside and it came out through the side, making a golf ball size hole. Two part epoxy and good as new. Tom
CJD
I'm sure it is...but in this case the tensioner will be pressing with some considerable force against the patch. I doubt that was the case with a tranny case.
Like I said, I do hope it works.
John
K
karls59tr
Bronze
I should clarify the type of crack that I was dealing with. It seems like it was kind of a V shaped flap. I'm hoping that the Epoxy will seal hard enough to keep the flap down. I know what you mean though about the tensioner pressure. Years ago I had to replace a timing cover as the tensioner had worn right thru to daylight. In any event it's summer and I just want to get some driving in rather than pull the whole thing apart again. Your concern is well taken and I'm definitely going to keep my eye on the repair. Seems like I'm always glancing under the car to check for leaks. :smile:
TomMull
Point well taken, John. However if I'm not mistaken I don't think the tensioner does the damage, rather an errant chain. In my case, there was very little wear at the point where the tensioner is supposed to contact on cover. Tom
CJD
I think it will get you through the summer...!
John
DanB
When mine wore through I found that the tensioner had broken and that caused the wear through.
Dan B
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
B TR2/3/3A Timing chain cover goop location Triumph 4
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
S TR2/3/3A timing chain cover and woodruff key Triumph 4
DanLewis Looking for a good timing chain cover Spridgets 1
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
doughairfield Install oil seal timing chain cover Triumph 9
lorendad Timing chain cover oil seal Triumph 3
glemon TR5/TR250 Front Timing Chain Cover TR250/6 Triumph 6
ronzet Quick Query re: TIming Chain Cover MG 3
R interal thread stripped on timing chain cover Spridgets 2
TR4 Timing Chain Cover is stuck? Triumph 7
Tinkerman Success w/ timing chain cover seal [aka sear0 Triumph 3
Tinkerman TR2/3/3A 60 TR-3A Timing chain cover. Triumph 8
L lowest bolts on timing chain cover MG 3
J oil leak at timing chain cover 1500 Spridgets 2
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B Timing chain tensioner help Austin Healey 15
G Timing Chain - Slackend Austin Healey 5
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
G TR4/4A timing chain and sprockets Triumph 9
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
TulsaFred Timing chain Spridgets 22
