TR2/3/3A TR3 Timing chain cover scroll seal......
TR4nut
Karl-
Hardest part is pulling the front hub - once off, just clean up the surface of the hub, then use the installation tool provided with the sleeve to tap it in place. There is a flange that is part of the sleeve that can be taken off after installation - slightly tricky but just make a cut on it and you can peel it off similar to taking of an old pop top.
Two parts that I know of can be made to work for this application:
99174:Shaft Size Min=1.747", Shaft Size Max=1.753", Width=0.563", Overall Width=0.688
or
99175:Shaft Size Min=1.747", Shaft Size Max=1.753", Width=0.75", Overall Width=0.875
The wider 99175 I think is superior - you can tap it on and you don't even have to remove the installation flange from the installed seal.
Not sure what places like Moss provide, I found just getting the seal directly from Napa etc is a cheaper option.
Randy
TR3driver
Great Pumpkin - R.I.P
:iagree:
I don't believe Moss even offered them when I got mine; but I suspect they offer the shorter one as that is what was listed in the CR (now SKF) application catalog.
You should be able to leave the flange in place even with the shorter sleeve, but you might have to not drive it all the way up against the shoulder. Measure and mark, so you can leave the sleeve centered over where the seal rides. I added a couple drops of Loctite "circular parts mount" just because I've got a great big bottle that I'll never use up, but it shouldn't be necessary.
Also, I learned that not all NAPA stores carry the same brand. One of my local stores said they couldn't even order a sleeve from CR, the other one said "No problem" and had it in about 4 days.
K
karls59tr
Bronze
Hi Randy thanks for the info. turns out I have the 99174. Just installed it. Is it necessary to remove the flange or can it be left on?
K
karls59tr
Bronze
Randal I sent my last post before reading yours about the flange.DOH! already driven it up to the shoulder so I'll have to check where it's going to ride now.
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
T TR2/3/3A tr3 timing chain question [master link] Triumph 2
H TR2/3/3A TR3 Timing Chain Triumph 13
jsneddon TR2/3/3A TR3 Timing Chain Triumph 14
BillyB62 TR2/3/3A TR3 timing/distributor question Triumph 7
G TR2/3/3A Advanced Timing Light for TR3? Triumph 6
M TR2/3/3A Timing the TR3 Triumph 5
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
M TR2/3/3A Setting the timing on TR3 Triumph 48
K TR2/3/3A The goop on the TR3 timing cover Again? Triumph 3
TRclassic3 TR2/3/3A TR3 Timing gears Triumph 5
mrv8q TR2/3/3A TR3 Static timing; point of confusion. Triumph 16
tinman58 TR2/3/3A TR3 timing? Triumph 5
RedTR3 TR2/3/3A TR3 Timing Question Triumph 3
PeterK TR4/4A TR3-4A timing cover tensioner Triumph 9
W TR2/3/3A Pertronix and timing in TR3 Triumph 20
MGTF1250Dave TR2/3/3A TR3 Static Timing with Pertronix Ignition Triumph 5
Tinkerman TR2/3/3A 60 TR3 Cam Timing Triumph 4
TRclassic3 TR2/3/3A TR3 timing and pertronix Triumph 8
M TR2/3/3A Cam timing TR3 Triumph 4
RedTR3 TR2/3/3A TR3 Timing Triumph 15
Tinkerman TR2/3/3A TR3-A Timing Cover Sear Removal Triumph 3
S TR2/3/3A tr3 timing gears Triumph 4
Earl TR2/3/3A TR3 Ignition Timing Triumph 8
MGTF1250Dave TR2/3/3A TR3 Ignition Timing Help Triumph 12
jscott TR2/3/3A TR3 timing Triumph 2
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
