timing chain sprocket
69tr
I have the cover off and ready to remove the chain and tensioner.
The chain has about 1/4 inch of deflection. Is that about normal?
The sprockets look to be worn a little. The teeth are not sharp but there is little space on the ends. What should they look like.
I apologize for all the basic questions but it will be easier to make the necessary repairs now.
Thanks, Pete
MGTF1250Dave
Aloha Pete,
I don't know specifically about the TR6 engine, but on the 4 cylinder TR engine, maximum allowable chain deflection between the sprockets is 10mm or about 25/64 inches. Here is an illustration of good sprocket teeth and worn ones.
TomMull
Here is a test from the hot rod guys: Timing chain test I don't think it is engine specific although this was worked out for V8s.
Even though your deflection (1/4) seems to be withing specs, my inclination would be to replace at least the chain and tensioner. Tom
69tr
On further inspection the cam sprocket shows signs of wear. The teeth are sharp.
I had planned on changing the chain and tensioner. I will also change the cam sprocket.
I have no idea of your engine build, but I building a TR6 engine right now and got a adjustable vernier style cam gear from BPNW, it retails for about 200 bucks, but you can dial the camshaft in exactly where you need as for timing for a performace camshaft, which we have for this engine. Nice piece I plan on documenting it's use on the forum here as we get into the assembly stage.
69tr
This did not start as a 'build'. I pulled the head to change the gasket and started checking some other stuff while I had it off.(see 'might as well' post) I will probably go back with a stock cam sprocket. The rest of the engine is stock and the car is a daily driver.(In the summer).
Thanks for the info though. Might be something for later when I win the lottery.
doughairfield Timing chain sprocket to camshaft Triumph 9
bash TR6 TR6 timing chain sprocket alignment Triumph 3
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B TR2/3/3A Timing chain cover goop location Triumph 4
B Timing chain tensioner help Austin Healey 15
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
TulsaFred Timing chain Spridgets 22
Darrell_Walker Timing chain tensioner wear Triumph 8
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
M TR4/4A tr4A timing chain procedure? Triumph 9
c5racer 1500 Timing Chain Upgrade to TR6 Spridgets 1
W TR6 TR6 Timing chain oil seal question Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
