Single HS2 on an 850 Mini Moke acting odd
pbraun
This 850 Mini Moke has sat for a few months only. Only reason I started messing with it was a stuck jet valve in the float bowl, so no fuel & wouldn
t start. Now it seems to have a sort of floating needle, as it wobbles with the needle screw in or out, tight or loose. Plus I can't remove it, even after multiple cleanings and soaking in PB Blaster penetrating oil.
The motor starts, but revs up quite a bit, then dies. The jet is up to even with the carb, choke is working fine. Float bowl fine and feeding gas. The carb was working fine a few months ago. I changed the gas and filter also.
So here's a pic of the piston and needle. Anyone have any ideas on this? I did find another HS2 that looks similar to this one, but doesn't have a wobbly needle. I have not tried swapping pistons, the older one is clearly much shorter.
I'll put some pics here.
Original piston/needle on left, shows holes, with wiggly needle, looks like 2 pics of same.
Here are top view, showing the older piston on the bottom, then on the right. I am open to any sugggestions.
pbraun
pbraun
I have found out the "floating" needle is correctly called a bias or swing needle. Doesn't help me now as the 850 won't run long enough to warm up. Still don't know what to do. The bias needle was running. The older carb has a fixed needle.
I will now look up the correct needle to have for a stock 850, if I can find it somewhere. I feel rather dumb here.
Platinum
Put the carb back together and check fuel delivery TO the carb. That needle is not the problem. This sounds like a supply issue.
Far less likely but possible is a coil failing as it gets hotter.
pbraun
pbraun
Replaced fuel jet in float bowl. Was previously stuck, now ok. I will pull the float bowl cover to check.
Getting spark. ???
pbraun
pbraun
Today is a rest day for me, with a good cigar. Then i will check all the ignition, and fuel delivery. It's got to be one simple thing or t'other!
LarryK
I always find problems are mostly simple. Just over thought and rushed. Good luck.
Scargo
Peter,
The correct needle for an 850 Moke would be a fixed needle in one of the the following three profiles:
GG - lean
EB - standard
M - rich
Since you changed the float bowl valve, make sure to check the fuel level in the bowl, and adjust it as needed.
Also, if you end up changing the piston, you should also change the suction chamber (dashpot), using the one that came with that piston,. to avoid a mismatch.
Where do you have the jet locking nut set ie: how many flats down?
Have you checked for vacuum leaks?
pbraun
pbraun
Yes Howard, have done all that - planning to go back and check it all . The jet nut only a few flats down.
Have any extra EB needles?
Scargo
I don't but it's a good bet that Joe Curto does.
As you most likely know, start out at 12 flats down and work from there.
pbraun
pbraun
Yeah - I heard he was so busy he wasn't accepting new orders, so I just ordered from mini mania. Cheaper that Seven Ent by the price of a locking choke cable. 12 flats down . roger. :smile: Think I may have just schrunched an EB by grabbing it . oh, well....
pbraun
pbraun
but searching a friend found the best buy on an EB needle on eBay at $15.
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
C LCB header with 1500 single carb inlet manifold Spridgets 1
shadowfever Single SU on Spridget Spridgets 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K WTD Single SU Manifold for AH Sprite Spridgets 0
R 1275 engine with SU HIF single carb Spridgets 9
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
drooartz Single stage vs base/clear Spridgets 29
M TR2/3/3A Single brake light modifcation Triumph 2
W Single Minator wheel available Spridgets 3
N DCOE double vs. single choke theory Spridgets 11
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
T building a single tower Sprite storage lift? Spridgets 21
J Bugeye single piece top frame same as two-piece? Spridgets 4
B Spitfire big bearing snap rings on Spit single rail Triumph 0
B Spitfire That Spitfire single rail gearbox again Triumph 2
N Convert BJ8 exhaust to single silencer Austin Healey 6
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
bigjones Single HS4 on a 1500 Spridgets 25
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
L Two screw or single bolt side view mirrors? Austin Healey 8
dklawson Single HS4 Conversion Troubleshooting Triumph 6
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
Ofcalipka Zienith single carb problems. Spridgets 34
Ofcalipka Zenith single carb problems MG 62
T Triumph Spifire - single rail gearbox sychro Triumph 0
M Help with single SU on midget Spridgets 19
bighealeysource single 12 volt battery conversion on a 1954 BN1 Austin Healey 9
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
dklawson Spitfire Spitfire - Single-Rail Gearbox Frustration !!! Triumph 20
dklawson Spitfire Spitfire Gearbox Swap - 3-Rail to Single [Parts?] Triumph 2
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
58Custom Anybody have schematic for single transistor tach? Spridgets 6
B single stage PPGpaint for Healey Austin Healey 15
beaulieu XK 120 Batteries - single 12v or pair of 6v ? Jaguar 7
T Single rail transmission Triumph 1
DART Huffaker "single hoop" MGB Racing 1
C Intake for single SU Spridgets 10
Aldwyn Single Headrest? Triumph 7
Randy Forbes Single [double jet] windscreen washer questions... Austin Healey 7
mgbmedic Single Zenith Carb- Results MG 1
mgbmedic Single zenith carb is a joke... MG 19
