Single Zenith Carb- Results
mgbmedic
Well, my forum friends, I've got to tell you how I remedied the single Zenith carb problem. I ordered from Moss a single SU carb kit that replaces the Zenith on 75 to 80 MGBs. This is a simple remove and replace set up that took about an hour to install. It's not a bolt and go, that is, it's not bench tested and pre-set to run on installation. So,you basically have two adjustments, jet adjust and idle, which is pretty simple. The carb is a HIF44 and has a 2" bore as opposed to the 1 3/4" of the Zenith. The problem I had with the original Zenith- it would not start up when the engine was cold and it had absolutely no power compared to my 69 B/GT high compression engine. Plain and simply, it was a dog! Well, after a little "tweeking" of the richness mixture setting, the test ride was one heck of a surprise. I didn't expect a big improvement, I just wanted the choke to work and the car to start 2-3 seconds after I turned the key. I would never have believed a single carb B would throw me back into the seat on take off, but , WoW...this ole LBC kicks like a mule. I am totally amazed at the difference...it's not the same car. I have a downdraft weber on my 76 B and there's no comparing the two. I highly recommend this conversion. Sorry Mr. Barnhill, there's no way I could get that out of a Zenith...what's your address...I have about 6 old ZS carbs your more than welcome to. (lol) Again, I appreciate everyone who responded to my post. I gotta go take another test ride, yeee haaaaa!!!!!!!
tony barnhill
Great Pumpkin - R.I.P
My address is on my website https://www.theautoist.com....I'm not going to disagree that you can't get more power from different setups - you can...all I'm saying is the ZS performs just as designed on the crappy manifold if properly maintained
Send 'em on - lemme know the shipping costs!
Ofcalipka Zenith single carb problems MG 62
mgbmedic Single zenith carb is a joke... MG 19
C LCB header with 1500 single carb inlet manifold Spridgets 1
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
shadowfever Single SU on Spridget Spridgets 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K WTD Single SU Manifold for AH Sprite Spridgets 0
R 1275 engine with SU HIF single carb Spridgets 9
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
drooartz Single stage vs base/clear Spridgets 29
M TR2/3/3A Single brake light modifcation Triumph 2
W Single Minator wheel available Spridgets 3
N DCOE double vs. single choke theory Spridgets 11
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
T building a single tower Sprite storage lift? Spridgets 21
J Bugeye single piece top frame same as two-piece? Spridgets 4
B Spitfire big bearing snap rings on Spit single rail Triumph 0
B Spitfire That Spitfire single rail gearbox again Triumph 2
N Convert BJ8 exhaust to single silencer Austin Healey 6
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
bigjones Single HS4 on a 1500 Spridgets 25
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
L Two screw or single bolt side view mirrors? Austin Healey 8
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
Ofcalipka Zienith single carb problems. Spridgets 34
T Triumph Spifire - single rail gearbox sychro Triumph 0
M Help with single SU on midget Spridgets 19
bighealeysource single 12 volt battery conversion on a 1954 BN1 Austin Healey 9
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
dklawson Spitfire Spitfire - Single-Rail Gearbox Frustration !!! Triumph 20
dklawson Spitfire Spitfire Gearbox Swap - 3-Rail to Single [Parts?] Triumph 2
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
58Custom Anybody have schematic for single transistor tach? Spridgets 6
B single stage PPGpaint for Healey Austin Healey 15
beaulieu XK 120 Batteries - single 12v or pair of 6v ? Jaguar 7
T Single rail transmission Triumph 1
DART Huffaker "single hoop" MGB Racing 1
C Intake for single SU Spridgets 10
Aldwyn Single Headrest? Triumph 7
Randy Forbes Single [double jet] windscreen washer questions... Austin Healey 7
