Wedge The Wedge Shop Single Turbo TR7V8 build
TheWedgeshop
Member
As some of you may know, or not know, I am have been in the process of building a Single Turbo Rover V8 setup for my 1977 TR7 FHC.
The motor will be a stock rebuilt 3.5 Rover with std compression (8:1) which is ideal for the turbo application. I will be using Cometic head gaskets,in which the heads have been shaved down to accommodate the extra thickness of these gaskets. Erson cams has designed a special grind pattern for the application that will be suited for the turbo application with power from 2500-6500. A Holley 750 blow thru carb will be made specifically for my setup. The Holley will sit on top of a Harcourt single plane intake manifold. The setup will be intercooled with 2.5in piping.
The transmission will be a stock rebuilt Rover trans LT77. The car already has The Wedge Shop Mustang rear end conversion and all the other goodies.
I will update the thread over time with my progress. I plan on making the turbo setup into a kit in which anyone can bolt on their stock 3.5 with no modification and push 250Hp to the wheels.
Here are some more specs on the setup.
Specs on Driving
Street car
1 -5 drag passes a year
Driven to cars shows 600+ miles
6300k Redline
Drive ability is important
300-350WHP Target
Quick specs on Motor:
215 cubic inch
Aluminum Block
Aluminum Heads
Fresh rebuild
ARP hardware
Cometic Headgaskets
Makes 210hp in NA form
Specs
Rover 3.5 (215 cu in)
8:1 compression
93 Pump Gas
ARP head studs, main studs
Stock Heads
Erson TQ20 on a 112 (478 lift, 214 duration at .050)
Cast pistons, rods
Single plane intake (Harcourt)
Blow thru Carb (Holley 750)
10-15psi max
Mallory 6 Box (Boost timing retard functionality run off MAP sensor 1* timing pulled per 1LB of boost)
Intercooler Core Size 11"X12"X3" Overall Size 18"x12"x3" 2.5" Inlet & Outlet 3" Core
3 in Mandrel bent exhaust from Downpipe back w/ Vibrant 3in Streetpower muffler
160* thermostat
Mallory SS distributor 24* advance with 10* static advance
1 PTE 46mm External Wastegate
1 Tial 50mm BOV
Garret to4e 60 trim .58 A/R O Trim T4 exhaust housing with 3in Vband outlet
attachment.php
attachment.php
attachment.php
Thanks
Clint
The Wedge Shop
www.thewedgeshop.com
Brosky
I saw it two weeks ago when I picked up a new stat for my TR8. It looks really good.
Nice work Clint!!
T
TheWedgeshop
Member
Finally got the car running correctly. Had to change out the carb hat and for the time being cut a hole in the hood.... Not my first choice, but had to get it to The Roadster Factory show and not having a hood that closes was not an option.
Here is a quick 3rd 4th gear pull. Car runs strong and am expecting 275-325whp when I get it back to the dyno.
https://www.youtube.com/watch?v=GSAYZ_Lsr...mp;feature=plcp
Thanks
Clint
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
David Townsend Wedge Limited Edition Wedge Prints Available Triumph 0
jfarris TR2/3/3A Thumb Screws for Wedge Side Curtains Triumph 4
PATR8 Wedge Help.... Wedge stalling out Triumph 1
Got_All_4 Wedge I need a new one of these. Wedge ac experts Triumph 5
PATR8 Wedge Where have all the Wedge owners gone Triumph 5
Marvin Gruber TR2/3/3A Need a pair of Wedge type side curtain mounts Triumph 3
aeronca65t wedge parts car for sale - NJ TVR 2
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
DNK Wedge Wedge Triumph 3
John_Mc Wedge Nice Wedge Triumph 6
glemon Wedge Is that all the love a Wedge gets? Triumph 14
DNK Wedge Wedge WP Triumph 2
PATR8 Wedge Wedge help needed Triumph 7
Darrell_Walker Wedge Wedge radio mounting Triumph 16
Darrell_Walker Wedge Drove the Wedge to work today! Triumph 6
K Wedge Taking the wedge to the Cape- Triumph 4
Darrell_Walker Wedge Reassembling wedge front suspension Triumph 6
glemon Wedge Low Mile Wedge Triumph 7
Darrell_Walker Wedge Removing Wedge strut cartridges Triumph 13
justin_mercier Wedge Took the wedge out for a little spin. Yay! Triumph 14
Darrell_Walker Wedge Wedge wheel adapters Triumph 14
Darrell_Walker Wedge Thought exercise - a wedge as a daily driver? Triumph 86
jclay Wedge Texas Wedge Ralley and Picnic! Triumph 10
John_Mc Wedge Wedge parade Triumph 7
WedgeWorks Wedge Wedge Tree Triumph 9
DNK Wedge Wedge Pumpkin Triumph 18
T Wedge BMW Recaro seats in a wedge Triumph 22
deadair Wedge wedge mount side curtains Triumph 11
DNK Wedge Wedge liners Triumph 10
philman Wedge good looking wedge on pdx craig's list Triumph 11
G Wedge A/C TVR 4
DNK Wedge Wedge PS Hoses Triumph 0
G Leven Hood Cover for a Wedge TVR 1
T Wedge Another Wedge head has joined us Triumph 60
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
P Wedge shaped Master Cylinder Reservoir 76B MG 0
JFS Wedge Wedge Glove Box Triumph 6
tr7andtvr Wedge rear end ratio swap? TVR 1
DNK Wedge Wedge and TRF Carpet and others Triumph 9
ChrisS Wedge [no this doesn't belong in the 'rumph forum] Spridgets 5
DNK Wedge Wedge Cover emblem Triumph 3
T Wedge Wedge Completes 24 Hours of Lemons Triumph 1
philman Wedge wedge rear suspension Triumph 8
jclay Wedge Wedge Technical Site Triumph 5
T Wedge Latest wedge has landed. Triumph 10
Mickey Richaud Wedge Nice Wedge on Ebay Triumph 22
PATR8 Wedge Wedge Seats Triumph 5
T Wedge Progress and a Wedge question Triumph 5
