Wedge Wedge radio mounting
Darrell_Walker
Does anyone have any pictures, diagrams or a description on how the factory mounted the radio? I received a RetroSound unit to install in my TR8 for Father's Day. The previous radio was a DIN-mount that was just shoved into the hole, and stuck out a couple to inches. I have some ideas on how to get it mounted, but I certainly welcome ideas from others that have already sorted it out!
DNK
No help from me ,Darrell. I had a radio shop do mine and it stuck out.
George_H
Just had a battle with that yesterday. a standard radio fits, but getting all of the wires out of the way is a huge challenge. It can be done. All of the tr7s I have seen have an aftermarket units in them. There is an original on ebay right now. Mounting looks the same as aftermarkets.
Darrell_Walker
Darrell_Walker
Hi George,
The RetroSound is quite small (and very flexible with the mounting). I was just wondering how they mounted a shaft-mount unit in the opening, which doesn't seem to have any provision for that.
I'm tempted with that unit on eBay just to get the Triumph faceplate!
-Darrell
DNK
Not if I beat you to it and hold it ransom!
George_H
The radio has 2 brackets on the shafts that fit between the opening and the faceplate. I would take a picture,but I'm NOT taking that thing out again.(ever!)
Darrell_Walker
Darrell_Walker
I don't blame you!
Darrell_Walker
Darrell_Walker
Any idea what these wires/connector would be for? The red/white wire is used for the dash illumination, but not sure what this would be for. Also, does anyone know where the white/purple wire for controlling the power antenna might come out? I have the connector in the boot, but I need to find the other end to connect to the radio.
DNK
Mine was on the pass. side of that area. you want a pic?
R/W ,for sure a light deal
Darrell_Walker
Darrell_Walker
Sure! I need to dig out and sort out the wires down that side still, hopefully it will be there.
That's what I thought, just can't figure out what it might be for. At first I thought perhaps for the FHC rear window defroster, but that is the opposite pattern. I also thought maybe for the radio illumination, but the wiring diagram doesn't show that.
Darrell_Walker
Darrell_Walker
BTW, found the power antenna lead, right where Don said. It was taped up with some other wires. Makes me happy that I don't have to worry about running my own wire!
DNK
Darrell, great, now I don't have to put my shoes on and go down and contort myself in the passenger well and take a pic.
Should anyway. For some reason,mine quit going up when the radio comes on.
Darrell_Walker
Darrell_Walker
I even hooked it up and verified that it works. Also found the fuse I fried when I put the battery in backward, and the old radio stopped working. Now maybe I can sell it for a few $$$, it is a decent Alpine unit. I had checked that fuse before but it looked fine.
Now I just need to work out how I'm mounting the new radio. I have one pretty good idea, if I decide that I can reinstall the center console with the radio already mounted. I'm thinking of glueing a universal face plate inside of the cutout. As long as I can make all of the connections before the console is all the way in, and if the radio won't interfere with putting the console back, it should work (and look) pretty good.
Also resisting the urge to replace the carpet, at least the section under the console, because I know where that would quickly lead :smile:
George_H
The only way I could get it in was to mount the radio to the console first. Then hook up the wiring then fight it like a dog. Be careful of the angle that the radio is in when mounted. if its not right, it will not fit.
Darrell_Walker
Darrell_Walker
Thanks, George!
I'm going to do a lot of test fitting before I commit anything for good. Luckily the RetroSound is quite small, and I could even remove the face from the body and remount at an angle, if I needed to.
GBRandy
With my DIN radio I installed the center console with all the wires hanging out the radio opening. The bulk of my wires & antenna were on the R/H side so I left the console mounting screw on the passenger side off.
As I worked the radio in I pulled the console side out and could reach in and help the wires & antenna along. Once the radio was in I cleaned up the wire loom and screwed the console side panel down.
Patience was a key here. In my younger days I would have just jammed it in and turned it on :smile:
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
David Townsend Wedge Limited Edition Wedge Prints Available Triumph 0
jfarris TR2/3/3A Thumb Screws for Wedge Side Curtains Triumph 4
PATR8 Wedge Help.... Wedge stalling out Triumph 1
Got_All_4 Wedge I need a new one of these. Wedge ac experts Triumph 5
PATR8 Wedge Where have all the Wedge owners gone Triumph 5
Marvin Gruber TR2/3/3A Need a pair of Wedge type side curtain mounts Triumph 3
aeronca65t wedge parts car for sale - NJ TVR 2
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
DNK Wedge Wedge Triumph 3
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
John_Mc Wedge Nice Wedge Triumph 6
glemon Wedge Is that all the love a Wedge gets? Triumph 14
DNK Wedge Wedge WP Triumph 2
PATR8 Wedge Wedge help needed Triumph 7
Darrell_Walker Wedge Drove the Wedge to work today! Triumph 6
K Wedge Taking the wedge to the Cape- Triumph 4
Darrell_Walker Wedge Reassembling wedge front suspension Triumph 6
glemon Wedge Low Mile Wedge Triumph 7
Darrell_Walker Wedge Removing Wedge strut cartridges Triumph 13
justin_mercier Wedge Took the wedge out for a little spin. Yay! Triumph 14
Darrell_Walker Wedge Wedge wheel adapters Triumph 14
Darrell_Walker Wedge Thought exercise - a wedge as a daily driver? Triumph 86
jclay Wedge Texas Wedge Ralley and Picnic! Triumph 10
John_Mc Wedge Wedge parade Triumph 7
WedgeWorks Wedge Wedge Tree Triumph 9
DNK Wedge Wedge Pumpkin Triumph 18
T Wedge BMW Recaro seats in a wedge Triumph 22
deadair Wedge wedge mount side curtains Triumph 11
DNK Wedge Wedge liners Triumph 10
philman Wedge good looking wedge on pdx craig's list Triumph 11
G Wedge A/C TVR 4
DNK Wedge Wedge PS Hoses Triumph 0
G Leven Hood Cover for a Wedge TVR 1
T Wedge Another Wedge head has joined us Triumph 60
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
P Wedge shaped Master Cylinder Reservoir 76B MG 0
JFS Wedge Wedge Glove Box Triumph 6
tr7andtvr Wedge rear end ratio swap? TVR 1
DNK Wedge Wedge and TRF Carpet and others Triumph 9
ChrisS Wedge [no this doesn't belong in the 'rumph forum] Spridgets 5
DNK Wedge Wedge Cover emblem Triumph 3
T Wedge Wedge Completes 24 Hours of Lemons Triumph 1
philman Wedge wedge rear suspension Triumph 8
jclay Wedge Wedge Technical Site Triumph 5
T Wedge Latest wedge has landed. Triumph 10
Mickey Richaud Wedge Nice Wedge on Ebay Triumph 22
PATR8 Wedge Wedge Seats Triumph 5
T Wedge Progress and a Wedge question Triumph 5
