Two screw or single bolt side view mirrors?
Legal Bill
The concours guide says my 1965 3000 could be equipped at the dealer with either the two screw side view mirrors or the single bolt. I think the single bolt has a cleaner finished appearance and would probably be more resistant to vandals, but you have to drill a big hole in your car to mount them. Plus I'm not sure if they look better on the doors or the fenders...
What doth the board thinketh??
The single bolt type are usually spring-loaded and retain their postioning when bumped. If you do elect to use two-screw type, be sure to use stainless threaded hardware with Nyloc nuts, as sheet metal screws will vibrate and/or strip themselves out.
Personally, I think the mirrors look best when mounted on the fenders, at the centerline of the front wheels. Not an isolated opinion, as I see LOTS of Healeys with similarly mounted mirrors.
Anybody saying that mirrors are not affective at that distance from the driver NEEDS to sit in my Healey, as the view from properly adjusted mirrors is astounding. Seriously.
GregW
Hi Randy,
Do your mirrors have flat glass, or are they convex?
GregW said:
Hi Randy,
Actually, I have both. While the flat mirrors were adequate, the convex ones allow me to see the back of my own head...
:wink:
L
Legal Bill
Randy Forbes said:
GregW said:
Hi Randy,
:wink:
Given my foliclly challenged hair style, that would not be good for me. I'd just be looking at the reflection of what is behind me.
AUSMHLY
There are many places to install the mirrors on the wings.
Measure twice, cut once the saying goes.
Placement on the passenger wing may be affected by the rear view mirror. If you raise your rear view mirror, to help see over the boot top, that may block viewing the mirror on the passenger wing.
Every situation is different. Size of person, seat placement may affect that line of sight.
Here's looking at you kid.
Johnny
I prefer mounting mirrors about 10-12" from the windshield on both front fenders on my BJ7. I used the single post mount and am happy with them. On the BN7 I used the door mounted mirror mfg. by Harley Davidson. They are of high quality and look nice. Got to remove them before putting up the side curtains though.
As for as originality goes if ordered from the factory they usually mounted them on the fenders near to center of WW as was noted. If ordered from dealers in the US they'd put them where ever the customer wanted them.
I suggest you check all out before deciding, it does make a difference as to your own height and personal tastes.
Jerry
The key is decide before you drill if you can get to the backside and put the nut on. I have one Healey with the mirrors mounted as per Randy, and I have mounted the mirror on the BJ8 on the door. I like that only because I can adjustment while seated in the car. The visability is less.
Jerry
BN4
BJ8
nevets Condenser Securing Screw Austin Healey 14
B Surprise screw head Restoration & Tools 0
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
G HD8 Idle Adjust Screw Austin Healey 10
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
R Grille Top Cowl Screw Austin Healey 7
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
T C42 BJ8 generator long screw needed Austin Healey 2
C TR6 ZS 175 What does this screw do? Triumph 2
JimLaney Rocker shaft plug/screw delima Spridgets 3
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 1
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 2
S T-Series screw size MG 0
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
M TR2/3/3A Where does this screw go? Triumph 6
B Rear Seats - Do I have to drill screw holes through the brand new leather upholstery? Austin Healey 13
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
Joe Reed General Tech Starting a screw in a tight location... MG 9
CJD TR2/3/3A Screw Post Coils Triumph 6
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
J SU HD6 - Slow Idle Screw Austin Healey 13
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
G Lens screw for AH 3000 BJ8 Austin Healey 1
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
P Fuel Float to tank bolts [machine screw] size?????? Spridgets 1
P BJ 8 broken hood frame screw Austin Healey 6
tinman58 TR5/TR250 Did I screw up? Triumph 4
Brooklands TR2/3/3A Set Screw Triumph 6
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
CanberraBJ8 screw size for window bracket? Austin Healey 3
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
GBRandy Wedge TR8 AF Screw Triumph 1
A TR2/3/3A TR-3A Trunk handle screw Triumph 10
S TR2/3/3A little adjusting screw tr3 Triumph 1
Gliderman8 Removing stubborn screw Restoration & Tools 22
H Side marker lens retaining screw Triumph 6
NutmegCT TR2/3/3A TR3 hard top screw Triumph 5
wangdango '96 XJR reversed battery charge screw up... Jaguar 2
sparkydave Rear view mirror set screw Spridgets 0
W How big a screw up? Spridgets 5
S Austin Healey 100 6 screw list Austin Healey 6
L Stripped windshield frame screw hole Spridgets 6
K TR2/3/3A TR3A Windshield Stanchion Screw Removal? Triumph 8
J Windshield pillar to windshield frame screw size? Spridgets 2
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
