TR2/3/3A Screw Post Coils
CJD
Yesterday I did the annual tune up on the TR3A. Even after R&R'ing the entire car, I learned something new. When I took the high tension coil wire off the coil, it had a simple press-in connector in the end of the wire, with a rubber sealing cap around it. Just like when I bought the car, and just like when I finished the restoration.
I went to spread the press-in connector for a tight fit in the coil, and realized something was not right. Well, having worked on the TR2, I now know what a screw in coil looks like...and it turns out the TR3A has one! All that has been holding the coil wire in for at least 3 decades is the friction of the little rubber cap.
Guess the old girl was jealous that all the parts were going to the TR2. This will be the first part I'll have to find for the TR3 in over 3 years!
GTP1960
I am regularly showing my ignorance.
but I fall back on " no such thing as a dumb question"
so what does a screw in coil look like?
thx CJD.
Guy
Vila
attachment.php
Where the high tension wire goes into the coil there are threads on the inside and the HT wire goes through a screw top piece that then screws down into the coil, thus holding the HT wire in place.
Sorry the picture imported sideways, tilt your head to the left, LOL
CJD
CJD
I'll take a pic looking inside the coil post when I get home. In the mean time, the coil looks pretty identical to a later coil at a glance, but the hole is larger, so a normal coil wire will never "click" when you push it in. With a closer look you realize that the sides of the hole are not metal, but plastic, and there are threads.
Vila
One more comment about the screw top coils.
First, I got a screw top coil that was painted black from one of the big three suppliers, I believe it was Moss.
When my restoration was nearly complete I found an original looking screw top coil in nature aluminum finish in England.
Each came with a the screw top part, and when I when to install the aluminum finish coil I had to change the screw top also since the length of the part that screwed into the coil was a different length. As I recall the aluminum finished coil required the longer screw top.
The Moss catalogue also shows the split brass washer required to hold the HT wire in place.
mrv8q
My '59 still has its original screw-top coil, dated 8/59, which matches the month it was built.
Don't know if that is especially noteworthy or not...
Went to check if the split washer Vila mentioned was still there, yep!
sp53
I guess if you had a carbon wire, you should lose more than a metal wire with one of those round copper slotted washers, but either way you would lose something because the connection would be a little lose, but again that tight rubber boot might hold the wirer in place, and if I remember my auto shop of the sixties, it takes 20K volts to jump through one inch of air and a coil should do that. In Washington State something like that would contribute to poor starting because of cool dampness. I guess Texas where you live is dry dry. You probably saw that you get one of those screw down deals. The correct ones with the older flared look are getting harder to find and so are the old coils. I bought a couple over the years, but really have not put them to a road test. I figured I would get to it someday, but again not fun to break down in traffic.
Tinkerman TR2/3/3A 1960 TR3A Instrument Cluster Ground Post Screw Triumph 9
nevets Condenser Securing Screw Austin Healey 14
B Surprise screw head Restoration & Tools 0
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
G HD8 Idle Adjust Screw Austin Healey 10
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
R Grille Top Cowl Screw Austin Healey 7
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
T C42 BJ8 generator long screw needed Austin Healey 2
C TR6 ZS 175 What does this screw do? Triumph 2
JimLaney Rocker shaft plug/screw delima Spridgets 3
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 1
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 2
S T-Series screw size MG 0
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
M TR2/3/3A Where does this screw go? Triumph 6
B Rear Seats - Do I have to drill screw holes through the brand new leather upholstery? Austin Healey 13
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
Joe Reed General Tech Starting a screw in a tight location... MG 9
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
J SU HD6 - Slow Idle Screw Austin Healey 13
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
G Lens screw for AH 3000 BJ8 Austin Healey 1
R TR4/4A Assembling the interior - dash support and radio plate screw holes don't match up Triumph 4
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
P Fuel Float to tank bolts [machine screw] size?????? Spridgets 1
P BJ 8 broken hood frame screw Austin Healey 6
tinman58 TR5/TR250 Did I screw up? Triumph 4
Brooklands TR2/3/3A Set Screw Triumph 6
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
CanberraBJ8 screw size for window bracket? Austin Healey 3
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
GBRandy Wedge TR8 AF Screw Triumph 1
A TR2/3/3A TR-3A Trunk handle screw Triumph 10
S TR2/3/3A little adjusting screw tr3 Triumph 1
Gliderman8 Removing stubborn screw Restoration & Tools 22
H Side marker lens retaining screw Triumph 6
NutmegCT TR2/3/3A TR3 hard top screw Triumph 5
wangdango '96 XJR reversed battery charge screw up... Jaguar 2
sparkydave Rear view mirror set screw Spridgets 0
W How big a screw up? Spridgets 5
S Austin Healey 100 6 screw list Austin Healey 6
L Stripped windshield frame screw hole Spridgets 6
K TR2/3/3A TR3A Windshield Stanchion Screw Removal? Triumph 8
J Windshield pillar to windshield frame screw size? Spridgets 2
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
