Stripped windshield frame screw hole
lbcfan
In drilling out the old screws I damaged (enlarged) two holes that I subsequently patched with an aluminum epoxy compound before installing the windshield glass. Unfortunately the screws won't hold in the repaired frame. The standing ridge within the frame that really holds the thread was also damaged - not just the hole.
Any suggestions on a repair from the outside of the frame? Do they make inserts this small? I got lucky with the glass installation once. Don't want to remove it and do it again...
Thanks,
Michael
Billm
I would epoxy the screws in the oversized holes. When it needs to come apart next you will have to drill out the screws but at least it will last for the next 10 or 20 years at which time someone else can worry about it.
BillM (a DPO if ever there was one)
L
lbcfan
Thanks Bill. Given how the old screws had seized in the frame I might as well use epoxy. Good thought.
Rut
I drilled mine out and put helicoils in. Very easy to do and you don't have to remove anything but the old screw.
Rut
L
lbcfan
I have ordered some ez lok 10-32 inserts. 5/16 od. I imagine they are the same? Glad to know it will work.
Michael
Rut
I actually used Perma-Coil brand 10-32 fine, pn 1208-201, and found it easy to use, but it does take a little practice and a drop of libricant going into aluminum. The kit is complete and you learn by feel using the supplied tool.
Rut
I Stripped screws in Bugeye windshield frame Spridgets 10
K TR2/3/3A Stripped threads in spark plug hole Triumph 8
JFS Wedge Stripped gearbox filler hole thread Triumph 3
S Stripped Threads Austin Healey 10
Basil 7 Ways to remove stripped screws Restoration & Tools 2
B Stripped Thread in Gas Tank Austin Healey 26
G TR4/4A Well...another stripped trunnion Triumph 8
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 8
M stripped threads on master cyl Spridgets 12
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 1
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
Johnny SU fuel pump banjo fittings stripped out Austin Healey 19
F New set of lug studs and stripped spines.... Triumph 12
P Stripped hood latch bolt Triumph 5
TRMark Being my own DPO, stripped front sealing block Triumph 6
J Stripped threads engine block Triumph 7
K Painting a car not stripped to bare metal? Triumph 6
TRclassic3 stripped pan bolts Triumph 4
Lon_S Stripped a cylinder head nut Spridgets 7
DanNagy Spitfire Spitfire 4: Stripped Triumph 5
Tr3aguy Stripped and resprayed pics Triumph 4
Tr3aguy Stripped parts...yes Triumph 8
H Stripped headbolt Triumph 23
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
tinman58 TR2/3/3A stripped bolt TR3 Triumph 5
John Moore Big Milestone! Tub is stripped Spridgets 6
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
davidk Stripped threads in oil pan front saddle block Triumph 12
M Block threads stripped torquing head Triumph 16
John Moore Front End Stripped and Questions Spridgets 20
R interal thread stripped on timing chain cover Spridgets 2
F GT6 GT6 differential mount stud stripped... Triumph 3
S Stripped bolt on timing cover Spridgets 17
Nunyas Stripped manifold bolts MG 4
drooartz I have a stripped Midget! Spridgets 16
B Paint Stripped..now Moss Motors or Victoria Brit? Spridgets 7
TexBug Stripped door hinge screw removal? Spridgets 4
T Question on primer after getting fenders stripped Triumph 16
J TR2/3/3A TR3 Master Brake Cylinder Stripped Fitting Triumph 1
Mark_Gibson Body Weight of a Stripped Down TR-2? Triumph 10
MattP Stripped Shifter MG 0
6 Stripped exhaust manifold stud Austin Healey 5
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
