Stripped screws in Bugeye windshield frame
ichthos
I have got a problem I need help with. The three screws on the passenger side are tight, however, two of three screws on the driver side post to the window frame are stripped. There is very little material for screws to hold on to to begin with, and this seems like a poor design to me. I currently have glass in the frame, and I have 10-32 half inch stainless steel screws securing the posts to the frame. I was just going to use larger screws, but the next screw I could find jumps to 1/4 inch, a little too big. Any ideas?
Kevin
Cram a sliver of aluminum foil into the hole (maybe 4 folds thick) and reinsert the original screws, not fancy but it works
BillM
I filled the hole with JB Weld and then drilled and tapped a new hole in mine.
You can get thread-repair kits at any good hardware store. One of the most common is a brand named Helicoil. You drill out the hole, tap it with a special tap, and screw in the helicoil insert. Then, you have a new threaded hole of the original size.
The other thing those screw heads on the windshield frame just might be PosiDrive Screws. I had mine apart to install windshield seal, and it really is easier and takes 5 minutes to do. Lots of PB Blaster in advance.IT came right apart.
I am pretty sure just about all of the screws were posidrive. They were so corroded in most cases that it took me a while to figure it out.
Thanks for all the suggestions.I should have checked all screw holes before I polished the frame and had the windshield installed. It has been a while since I have worked on the windshield frame, and I simpley forgot. The four screws were heck to get out, and now I remember why there were two screws missing. I tried the foil trick, but I think the two holes are too messed up for that to work. I think I would like to try the helicoil. How difficult are these to install? Can I do this with the glass in the frame? I guess I will have to figure out what size screws they are. What will a parts store need to know? Will it make a difference that I am working with aluminum?
Kevin
Helicoils are pretty easy to install, especially in aluminum! It basically a set screw with a threaded hole thru it. You drill and tap an over size hole and thread in the coil. The center threads are now your new threads. As for doing it with glass installed, that sounds trick but if you take your time it might be do able. Good luck
I ordered a Helicoil kit and it should be here Wednesday. My first time trying this. The inserts themselves are only about 3/8" deep, so I should be able to pull it off with the windshield in place if I take my time. It is scary to me to think of what little is protecting the driver with this windshield arrangement. I may very well be looking into a roll bar later.
Kevin
LOL yeah that windshield will fold faster than a lazyboy in a roll. I'm definitely will install one in mine before I take it on the road.
If you find a Roll Bar for sale you can get it UPS'd across the country for $50. Just slap a shipping label on it and call for a pickup. I bought one from CA for Bugsy my '68 Sprite that way.
Basil 7 Ways to remove stripped screws Restoration & Tools 2
K TR2/3/3A Stripped threads in spark plug hole Triumph 28
JFS Wedge Stripped gearbox filler hole thread Triumph 3
S Stripped Threads Austin Healey 10
B Stripped Thread in Gas Tank Austin Healey 26
G TR4/4A Well...another stripped trunnion Triumph 8
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 8
M stripped threads on master cyl Spridgets 12
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 1
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
Johnny SU fuel pump banjo fittings stripped out Austin Healey 19
F New set of lug studs and stripped spines.... Triumph 12
P Stripped hood latch bolt Triumph 5
TRMark Being my own DPO, stripped front sealing block Triumph 6
J Stripped threads engine block Triumph 7
L Stripped windshield frame screw hole Spridgets 6
K Painting a car not stripped to bare metal? Triumph 6
TRclassic3 stripped pan bolts Triumph 4
Lon_S Stripped a cylinder head nut Spridgets 7
DanNagy Spitfire Spitfire 4: Stripped Triumph 5
Tr3aguy Stripped and resprayed pics Triumph 4
Tr3aguy Stripped parts...yes Triumph 8
H Stripped headbolt Triumph 23
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
tinman58 TR2/3/3A stripped bolt TR3 Triumph 5
John Moore Big Milestone! Tub is stripped Spridgets 6
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
davidk Stripped threads in oil pan front saddle block Triumph 12
M Block threads stripped torquing head Triumph 16
John Moore Front End Stripped and Questions Spridgets 20
R interal thread stripped on timing chain cover Spridgets 2
F GT6 GT6 differential mount stud stripped... Triumph 3
S Stripped bolt on timing cover Spridgets 17
Nunyas Stripped manifold bolts MG 4
drooartz I have a stripped Midget! Spridgets 16
B Paint Stripped..now Moss Motors or Victoria Brit? Spridgets 7
TexBug Stripped door hinge screw removal? Spridgets 4
T Question on primer after getting fenders stripped Triumph 16
J TR2/3/3A TR3 Master Brake Cylinder Stripped Fitting Triumph 1
Mark_Gibson Body Weight of a Stripped Down TR-2? Triumph 10
MattP Stripped Shifter MG 0
6 Stripped exhaust manifold stud Austin Healey 5
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
PAUL161 T-Series 55 TF Floorboard screws MG 4
J TR4/4A Washer bottle bracket screws Triumph 3
S TR2/3/3A the large Philips headed field screws Triumph 12
