Hey Guest! BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF helpful, appreciate no pop up ads, and you want to ensure we stay online - Please support us with an "optional" low-cost (less than many car club dues) member upgrade. There are some benefits to upgrading!
Topped up my brake fluid yesterday. Accidentally pour about a thimble full of DOT 5 in with the DOT 4 already in the master cylinder. Is that going to cause me issue?
The mixture may gel and result in very poor braking; I would purge the system to prevent gelling with the DOT 4. Or you can just wait and see, but if it does gel you may have a more difficult time in removing the contaminated fluid.
If you haven't driven it and mixed the fluids I think I would try to suck out whats in the reservoir. Large syringe or oil removal gun that used to be carried by auto tool suppliers. Should not be to difficult.
I have had a jar with a 50/50 mix of DOT4/DOT5 on my workbench for a couple of years. Periodically I give it a good shake. The 2 fluids mix for a while but separate over time. There is no sign of a Gel or any other nasty interaction. One interesting point is that the purple dye seems to have migrated from the DOT5 to the DOT 4. You need to make your own decisions when it comes to brakes but if it were mine, I wouldn't sweat a small amount of 5 in your system.
The 5 is less dense and floats on top of the 4 so it should be easy to use a baster to suck off most of it.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
