Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear
Stinger
Its time to have our TR4A painted and would like some opinions on single stage paint compared to base coat clear coat. Thanks in advance.
martx-5
The TRs never came with a clear coat, however, there certainly are advantages. When I painted my TR3, I chose NOT to clear coat it, as I didn't think it would look right on the car. This is a personal decision that you have to make.
TR6oldtimer
The single stage paints of today are a lot more glossy, reflective as you will, then the enamels of the era. If you shoot a single stage urethane it will look like the clear, but not as deep. The last time I shot acrylic enamel, it was much less reflective. A base/clear or a single stage then clear give you bit more UV protection for the underlaying color. Not that it matters as much, because most of these cars spend most of their time in the garage.
I went the clear coat route as I remember when I first had the car, trying without success to get the mirror look in the original paint that it could not give.
Like Art said, it all depends on the finish you want.
trrdster2000
Stinger, it's getting near car show time in a lot areas, so if it's not a pressing issue, go look at some of the cars in shows and you will get a better idea what looks good.
On the BRG, go watch it being mixed, when you think is dark enough add a quart of black, now that's BRG.
Wayne
DougF
I painted my TR6 in single stage urethane with no clear coat and often regret it. The Mallard Blue paint holds a very good shine, but oxidizes quickly to the point of having to buff it at least once a summer. The car is garage kept.
The Black base/clear I used on my TR3 held up very well for 14 years without needing touched.
Britishautobody
I have a finished dark green Healey on my web site video ,a 67 it is clear coated I think you will find it very nice! Clear coat is less maintainence,easier to repair,less brittle,more UV protection, very flexible a all around better product.
I have seen a few enamel jobs that looked so good I couldn't tell they weren't clear coated,but I know they are more brittle of a finish and more work to maintain.
glemon
On the personal taste issue I agree that basecoat clearcoat does not look like the cars did when new, but neither does a single stage catalysed enamel.
If you want the high gloss show car look go with base/clear
If you want a more original look go with single stage.
I know a number of auto body guys, they are all sold on basecoat clearcoat, supposedely easier to apply easier to repair.
May be true for the body shops, but don't know so much for the home painter.
Less material cost,less steps to screw something up (if you are a pessimist).
Modern catalyzed enamels blend pretty well even if single stage.
The GN25 paint code is a very dark green, would not mix it then add more black, it looks close to black in some light already.
There are numerous "BRG" codes, MG has a fairly light color, too light in my book, Triumph Racing Green is lighter than GN25 but still pretty dark, a very nice looking color on most any British car in my opinion.
SCguy
My TR4 is single stage.
Britishautobody
You know it is funny how people keep bringing up wanting a finish close to factory non super gloss etc . I never hear mention of wanting factory runs that almost all of the cars had in the engine bays ,door jambs,under the trunk areas, why is that?
Or wanting the terrible " factory fit and gaps" these cars are notorious for straight out of England. I can see being anal to a certain degree.
Where does one draw the line?
In a day of new cars with perfect gaps, all the options,glossy finishes,why not preserve these cars in a higher standard?
dklawson
Very true. When I finished my last paint job a friend of mine pointed out that the finish was MUCH better than it would have been when new.
On the topic of base/clear vs. single stage, there is a compromise - both.
As an example, the last full car I painted was the Mini. My PPG paint supplier suggested a modification to the "normal" painting method as recommended on the data sheets. Their advice was to put down two coats of single stage as normal. For the third and final top coat he suggested mixing the paint 50% with PPG's clear (DUU?) that was compatible with my single stage (DCC?). The result is a bit more gloss and the paint can be wet sanded and buffed to achieve whatever result you are after. I liked the results.
glemon
Doug, thanks for posting that remark, I had seen someone else say that too, may be the way I go, SCguy the TR4 looks great, Greg
TR6oldtimer
Doug, I too used a single stage urethane, color sanded, then a clear over it, color sanded, then buffed(if I were a better painter, this would not have been necessary). The main reason for my choice of the clear over the single stage was to get additional UV protection for the Mallard Blue. It also helps if when doing the final sanding an buff, you go through the clear, you still have shine underneath.
MDCanaday
A lot of people are put off on the idea of a base/clear cause they see how badly the Detroit boys mess it up(peelers).High quality paints will not give this problem unless parked in the sun for many years with no care. I have to side britishautobody here,the original paint was low tech and generally not too pretty or even durable so why get nostalgic over it?? I say invest in a HIGH quality base clear and get the advantage of better shine and durability over single stage paints.The added UV protection is the big difference.The chemistry of paint pigments is now all petro based,they need to be shielded from harsh UV or they fade like crazy.Gone are the days of lead based pigments or any of the metals that were used "back in the day"to make colors bright.
MD(*mad dog)
S TR4/4A TR4A BRG #75 paint code Ditzler 42487 Triumph 3
Sarastro TR4/4A Original TR4A paint: enamel or lacquer? Triumph 4
J TR4/4A 67 TR4A Generator Paint Colour Triumph 5
Stinger TR4/4A TR4A Just Back From The Paint Shop Triumph 21
Stinger TR4/4A Original TR4A Paint Triumph 7
K TR4/4A TR4A Paint...Royal Blue? Triumph 6
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
A TR4/4A TR4A commission tag paint and trim codes Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
