Spitfire Aftermarket synchros 1500 Spit single rail
bnw
What's the deal with the aftermarket synchros being worse than the ones they are replacing? I just replaced all four because the 2/3 was grinding, now they all are grinding.
TR3driver
Great Pumpkin - R.I.P
Not sure if it's the same problem, but there were a whole bunch of bad synchro rings on the market a few years ago for the 'big' Triumphs. Lots of theories as to what was wrong with them, but I don't think any of theories was proven.
Maybe you could find some NOS? (That's what I did for my TR3A.)
71MKIV
It's also a very fiddly process to get everything back together with all the clearances correct. If you go over to the spitfire squadron site and talk to Paul T over there, he has documented that whole procedure and why the new synchros have issues sometimes.
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
roscoe Aftermarket Seats with Headrests Austin Healey 9
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
Y MGB Aftermarket wheels MG 5
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
kodanja TR2/3/3A Aftermarket Sun Visors? Triumph 12
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
Z TR2/3/3A Windshield Aftermarket Triumph 22
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
B 100-4 Aftermarket Hardtops Austin Healey 7
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
S TR4/4A aftermarket choke cable Triumph 3
Csarneson Rear Springs - Aftermarket or buy an old used pair Austin Healey 10
W TR6 tr6 horn aftermarket Triumph 1
T TR6 TR6 aftermarket rear shocks Triumph 35
NutmegCT Aftermarket a/c? Restoration & Tools 15
T TR2/3/3A Question on TR3A aftermarket side curtains Triumph 8
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S TR2/3/3A aftermarket trunnions? Triumph 6
R Installing an aftermarket brake servo kit Austin Healey 6
F Thoughts on aftermarket air cleaners? Austin Healey 12
J aftermarket sheetmetal Spridgets 2
66healey Aftermarket brake booster pictures Austin Healey 7
Gray_Cat Bugeye Aftermarket Steering Wheels Spridgets 15
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
Branson Aftermarket wiring harness + original sprite wire Spridgets 5
R Red, white and tan covert tops aftermarket 60's? Triumph 11
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
RJS Aftermarket Cooling Fans Triumph 3
W TR6 TR6 aftermarket headers Triumph 26
newmexTR3 TR2/3/3A Aftermarket headlight relay mounting options TR2-4 Triumph 5
S MGB Aftermarket starter for 66 mgb MG 9
King_of_England aftermarket gear reduction starter failure Triumph 10
M TR6 ??TR6 steering wheel NOS or Aftermarket on ebay?? Triumph 7
Don_R Aftermarket Steering Wheel Triumph 7
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
R TR6 TR6 Aftermarket Seatbelts Triumph 4
Editor_Reid Rare 100 Aftermarket Accessory Austin Healey 7
rustbucket T-Series Original vs. Aftermarket Cutch MC & Slave MG 4
71TR6 TR6 Aftermarket TR6 Steel Wheel Triumph 3
R TR2/3/3A TR3 Hardtop OEM or Aftermarket Triumph 21
K TR6 Custom Hardtops - aftermarket top TR6 Triumph 11
AUSMHLY Survey - stock, hybrid, aftermarket steering wheel Austin Healey 37
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
v8mgbal aftermarket steering wheels Spridgets 19
B Aftermarket Radio Install Spridgets 28
