Single [double jet] windscreen washer questions...
Is this the only style of single jet windscreen washer fitted to early 100/6 models?
Seems like my car used to have an exagerated diamond shaped one when it was in San Francisco (some 25+ years ago).
Also, what does the fitting on the underside look like? It seems to be a 1/4 x 28 thread, so I guess I can machine/weld something up to accept the tubing, but it would be nice to see what it's supposed to look like...
Thanks!
DerekJ
Randy
I believe that to be the only type of washer jet used on Longbridge BN4s. I have never seen a triangular one.
I will check my car when I get chance to see if I can determine whats underneath! I'll keep you posted.
Randy Forbes
[ QUOTE ]
Randy
[/ QUOTE ]
Thanks Derek.
My car was built at Abingdon, but it is a very early 2-seater that still had the glass reservoir and single squirter. /ubbthreads/images/graemlins/cheers.gif
healey106
Randy - the photos, show the correct windscreen washer unit for the Longbridge "featured" BN4. Just for informational purposes, what is is the car # of your Abingdon BN4 with the Longbridge "features"? Jim /ubbthreads/images/graemlins/driving.gif
Randy Forbes
[ QUOTE ]
[/ QUOTE ]
BN6L-942 two-seater.
(it's the one on the left /ubbthreads/images/graemlins/wink.gif )
DerekJ
Randy
That is very interesting - I hadn't realised that some early BN6s had a single washer.
However this probably makes sense because we know that the glass washer bottle was introduced from BN6 #1182 - its logical to assume that the complete new assembly was introduced at the same time. This would include the Bakerlite washer push with white lettering and also the two washer nozzles. If this is the case then your car would have had the old style chrome washer push. Do you know if it did.
You can see photos of these original fittings on the 100-Six site at
https://www.healeysix.net/Longbridge2.htm
DerekJ
Randy
Correction to above. Of course it should have said the PLASTIC water bottle was introduced from #1182. It was glass until then.
I looked at my single washer and it seems to be fastened in place by a simple washer and nut. It is fairly easy to get at under the dashboard. My car was totally rebuilt so I can't say that type of fastening is original.
Randy Forbes
Thanks Derek, the link showed some interesting details.
I used to have the all chrome washer pump, but it disintegrated a couple decades ago (the internal rubber just crumbled and the stem was dangling). I have no idea what happened to it.
I have devised a plan to make the fitting for the underside of the screen jet, just need the time to implement it.
N DCOE double vs. single choke theory Spridgets 11
T Spitfire Replacing single ZS on 1973 Spit with double Triumph 1
S single pole or double pole? Triumph 6
C LCB header with 1500 single carb inlet manifold Spridgets 1
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
shadowfever Single SU on Spridget Spridgets 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K WTD Single SU Manifold for AH Sprite Spridgets 0
R 1275 engine with SU HIF single carb Spridgets 9
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
drooartz Single stage vs base/clear Spridgets 29
M TR2/3/3A Single brake light modifcation Triumph 2
W Single Minator wheel available Spridgets 3
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
T building a single tower Sprite storage lift? Spridgets 21
J Bugeye single piece top frame same as two-piece? Spridgets 4
B Spitfire big bearing snap rings on Spit single rail Triumph 0
B Spitfire That Spitfire single rail gearbox again Triumph 2
N Convert BJ8 exhaust to single silencer Austin Healey 6
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
bigjones Single HS4 on a 1500 Spridgets 25
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
L Two screw or single bolt side view mirrors? Austin Healey 8
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
M Carb Conv Kit, Weber Single Downdraft conversion Spridgets 15
Ofcalipka Zienith single carb problems. Spridgets 34
Ofcalipka Zenith single carb problems MG 62
T Triumph Spifire - single rail gearbox sychro Triumph 0
M Help with single SU on midget Spridgets 19
bighealeysource single 12 volt battery conversion on a 1954 BN1 Austin Healey 9
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
dklawson Spitfire Spitfire - Single-Rail Gearbox Frustration !!! Triumph 20
dklawson Spitfire Spitfire Gearbox Swap - 3-Rail to Single [Parts?] Triumph 2
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
58Custom Anybody have schematic for single transistor tach? Spridgets 6
B single stage PPGpaint for Healey Austin Healey 15
beaulieu XK 120 Batteries - single 12v or pair of 6v ? Jaguar 7
T Single rail transmission Triumph 1
DART Huffaker "single hoop" MGB Racing 1
C Intake for single SU Spridgets 10
Aldwyn Single Headrest? Triumph 7
