Capillary tube of oil/temp.-gauge as single part ?
germanmichel
Hello @ all,
on my combination gauge water /oil it is a little "break" in the turned capillary tube. Does anyone know, is it possible to remove the tube as a single part. All supplier offer only the gauge assembled with the tube. But I would like to use my silver orginal gauge,not a new moss part.
I understand that the gauge has to be adjusted after tube changing.
Thanks in advance.
Bye Michel- who find every day new restoration challenges :laugh:
Flachs
Hallo germanmichel,
im Forum des MGDC findet man viele Tipps, welche auch fĂĽr den Healey passen.
https://www.mgdc.de/cms_de/index.php?option=com_wrapper&Itemid=80
ich zitiere z.B.
versuch es mal hier:
Dipl. Ing Rudolf Mensebach
Euskirchen
Tel.: 02255 6737
Mail: rudolfo.technikus@web.de
Reparaturpreis 2002: 40 Euros
Reparaturzeit: ca. 7 Tage
Neues Kapillarrohr, neue GasfĂĽllung, Kalibrierung
Keine Reparaturen an der Anzeigemechanik.
GruĂź aus Bayern
Michael F.
Vor ein paar Jahren hab ich eine MG midget restauriert.
z.Zt. habe ich eine Healey BJ8 zerlegt. Der hat das gleiche Smiths Kombi-Instument
Wie hast du den FĂĽhler aus dem Zylinderkopf rausgebracht?
Folgenden Artikel fand ich erst als ich die Mutter mit Hammer und Meissel gelöst hatte.
https://www.team.net/www/healey/tech/big_hly/tools/temp_sensor.html
germanmichel
germanmichel
Hello Flachs and zblu,
thank you very much for information. This was an really just in time support :thumbsup: (and for me easy to read...)
My Triumph TR6 did not have this kind of "pre-war" technology like my BT7. So this technology is completly new for me. It sounds very good for me to go to a specialist. But I think the price from 2002 will be "upgrated" :yesnod:
Thanks
Michel-who will fix this item and has to change the positiv motor ground wire (no current over the capillary tube)
zblu said:
Maybe phoscopper wire and silver solder flux
But the tube still needs to be filled with alcohol; how're you going to do that?
This is a repair for a specialist.
R
RonMacPherson
I recommend going to the MG forum(gasp! heresy).
There have been several very informative threads about repairing, replacing, refilling and adjusting these capillary gauges. One fairly recently that caught up the basics for everyone. One a year or so ago that went into fine detail and explanations. It might even be in the wiki forum...
andrea
ATTENTION the water temp. capillary is filled with very flammable solution before cut it you must put the sensor on one cup of ice to avoid the instantaneous evaporation of solution inside-
this is not a thermometer but temperature are find on the basis of pressure generate by the evaporation
-for the reparation of the capillary I can give you the instructions to do it
The oil pressure gauge are no critical --capillary can be cut without particular caution
stevebn2bj7
My local gauge rebuilder replaced the entire capilary tube when he rebuilt the gauge a few years back. Did not seem to be any particular problem in doing this.
D Capillary Oil Tube Fastener Austin Healey 5
M Capillary Tube repair Spridgets 4
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
R Capillary tube temp gauge Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
woolfman General MG Replacing capillary tube MG 10
T TR2/3/3A Capillary Tube Clips Triumph 4
B Temp gauge capillary tube Austin Healey 3
S Temp gauge capillary tube Austin Healey 8
mountainman TR 3 Temp Guage Capillary Tube Triumph 6
martx-5 TR2/3/3A TR3 Capillary Tube Clamps Triumph 16
R Temperature capillary tube removal Austin Healey 10
M BN4 Capillary tube attaching Austin Healey 2
CharlieCarpenter What tool to use to disconnect capillary tube Austin Healey 6
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
Tinkerman TR2/3/3A Attaching the temp capillary to the fuel line. 3A Triumph 13
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
Atrus 1/8” Capillary Tubing [Dizzy Advance] Spridgets 8
C Capillary pipe clip Austin Healey 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
P MGB Tube axle wear MG 3
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
