Temperature capillary tube removal
Ray7Smith
Am having one heck of a time trying to remove the capillary tube from the head on my BJ7. Aside from purchasing a specialty wrench, does anyone have suggestions on removal of said item? Is it permissable to use heat in an attempt to get the nut on the tube lose, or would this damage the capillary tube?
Ray
Try some crc and gentle hits with a small hammer with a piece of metal held firmly against the flat of the nut on the opposite side, probably tight due to metal difference action ie brass into cast iron, might be enough to break the nut loose
Hi Ray,
After liberal application of penetrating lube, tapping and time ...
You can take a deep socket and using a hand grinder or mill (the better way) cut a slot from the 'socket end' almost all the way to the drive end. The slot needs to be wide enough to allow the capillary tube to fit through. Open a hose clamp and reassemble it over the tube, slide the socket onto the nut and tighten clamp to keep the slotted end from expanding. Sometimes it helps to apply pressure to tighten the nut first (breaking things loose) before applying CCW direction to remove it.
Cheers,
John
Ray,
If you search through the archives, there have been some recent threads talking about this subject. They cover methods and some very simply home-made/modified tools.
Search for "Temperature bulb removal" and "thermostate fitting in eng. block" in the Healey section. The second search will get you the better thread.
Mark
I saw some crazy wrench at Home Depot that grabbed the nut at 90 degrees from the handle. Being adjustable, it had open sides. I am not sure how thick it's sides were to get into the tight space required. It was about 1 1/2 inches long at the business end (adjustabble socket). I know I'm not discribing this well but it wasn't very expensive.
Similar to the above, I slotted a standard box wrench. Sender came out in no time. Juice it up good as the nut portion of the fitting has to rotate around the cap tubing. Bob
Hi Ray,
Most of the time that I have a brass fitting in a engine block or cylinder head that won't move,I tighten it a bit and then loosen it . Just tighten it enough to see it move and then she'll come out. Works for me and I hope for you.
Good Luck!!
Bobby R
Ray
I ground out and modified the outsides of an open ended spanner that had a strange crank on the end that could have been just made for the job, it worked for me.
Bob
Hey Guys, finally got the tube out without destroying anything. Feels nice to save $150.00.
As always, the people on this site are real life savers when it comes to sound advise.
Thanks,
Ray
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
BierRunner TR6 Temperature Gauge Triumph 8
A MGB Stuck water temperature sensor MG 26
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Coolant temperature gauge Spridgets 8
nevets Coolant Temperature Austin Healey 13
longbridgehealey Temperature sender Austin Healey 18
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR2/3/3A TR3 Temperature gauge Triumph 19
B Temperature Sensor Removal Austin Healey 10
R Temperature sensor Help me Austin Healey 18
S Meaning of the ‘dots’ under the temperature scale? Austin Healey 3
GS67 1500 Operating Temperature Spridgets 2
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N BT7 water temperature sensor removal Austin Healey 13
pkmh How hot can it [temperature gauge] get? Austin Healey 4
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
S BJ7 frozen temperature sensor to block Austin Healey 17
K TR2/3/3A Temperature Gauges Again Triumph 5
S TR2/3/3A Temperature Guage Triumph 3
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
BN6_2197 Question on correct oil temperature Austin Healey 15
Bugeyze Temperature Austin Healey 14
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Temperature sensor size where it fits in the housing? Triumph 4
K TR2/3/3A Replacement Temperature Gauge Triumph 5
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
Dave Richards Temperature Guage Austin Healey 11
J 1964 AH 3000 operating temperature Austin Healey 10
BN6_2197 BN6 Temperature Issue Austin Healey 12
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
andrea Problem with the throttle linkages due hing external temperature Austin Healey 34
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
GBT MGB-GT air temperature control valve MG 1
B Path of Oil Pressure/Temperature Lines Spridgets 2
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
Tugboat TR2/3/3A Original T3A Temperature Gauge Triumph 13
Anthony_S temperature gauge....HELP Triumph 18
Nelson "High" temperature adhesive Spridgets 7
