TR 3 Temp Guage Capillary Tube
mountainman
Just got my temp gauge back from being rebuilt and was getting ready to install. My questions is how careful do I have to be about bending the line. I thought I read somewhere that the line has mercury in it and do not want to crimp it.
Thanks
Greg
martx-5
The bulb and tube are filled with ether, not mercury. Kinking the line might cause the tube to crack, which would let out the ether and put you to sleep! :laugh: The coiled wire around the tube is there to (hopefully) prevent this from happening.
A reasonable amount of care is all that is necessary. Be sure to check out how the tube is run and coiled at the back of the engine. It's coiled to prevent vibrations and engine pitching from breaking it. I'll see if I can dig out the diagram if you don't have it.
martx-5
Here's a diagram of the capillary tube routing.
Geo Hahn
That about covers it. You might wrap around a juice can or such for that 3-turn coil just before it enters the firewall. I have heard lengthy (and heated) debates about the correct radius of that coil.
Also, I always use anti-seize on the fitting that secures the tube to the thermostat housing. Dissimilar metals there can make it difficult to undo years down the road.
TR3driver
Great Pumpkin - R.I.P
Geo Hahn said:
Also, I <span style="font-weight: bold"><span style="font-size: 12pt">always use anti-seize</span></span> on the fitting that secures the tube to the thermostat housing. Dissimilar metals there can make it difficult to undo years down the road.
:iagree:
BTW, I believe it's petroleum ether, not the same thing as anesthetic ether. Still not something you'd want to drink, and I imagine enough of it would still put you to sleep (perhaps permanently), but there is also not enough of it in the gauge to worry about IMO.
The main concern is that letting it out will render your freshly rebuilt gauge useless until it's rebuilt again.
dklawson
I also agree about the anti-seize. It's a "must do" step during the installation.
alfa33047
Hi Greg, If you look at the picture of the routing of the wire to the gauge, you notice that under the dash it is in a circle. What is not in the picture is the heater core and the wire wrapes around the heater core. In looking at the picture it does not show the heater. Good Luck, Bill C. Mesa, Az.
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
S TR4/4A Temp guage problem Triumph 5
S Temp and Fuel guage not working Triumph 4
JohnnyMead TR2/3/3A TR3 - Routing the Temp Guage Tube? Triumph 5
pipercollins Running Temp, Guage, Sender Questions Triumph 11
jlaird Water temp/oil pressure guage Spridgets 3
B TR2/3/3A ELECT TEMP GUAGE WIRING FOR TR-3? Triumph 3
AweMan TR2/3/3A TR-3 water temp guage Triumph 10
L Temp and Fuel Guage MG 10
Banjo Lucas gremlin in the temp guage MG 3
Baz Temp guage not working Spridgets 51
M Checking a temp guage Triumph 2
Tullamore Engine Temp Guage Spridgets 7
martx-5 Water Temp Guage Repair Triumph 2
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
G Smith's temp gauge repair Restoration & Tools 4
MikeAH100M High Temp Engine Miss Austin Healey 2
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
shadowfever Water temp Spridgets 9
Govtslug TR6 Coolant Temp Q Triumph 4
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Editor_Reid Water Temp Gauge Austin Healey 5
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Rut Bugeye 1275 temp probe placement. Spridgets 8
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A temp gauge sealer Triumph 7
W Electrics, fuel system, under bonnet temp. Austin Healey 3
S TR2/3/3A removing the temp gauge needle Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
JFS TR2/3/3A Radiator fan temp probe Triumph 3
JFS TR2/3/3A Temp Sensor Removal Triumph 6
R Capillary tube temp gauge Austin Healey 7
R TR2/3/3A TR3A tired temp gauge Triumph 5
RickPA Water temp gauge reads low Austin Healey 6
F TR2/3/3A Water Temp Triumph 10
vette Threads for the Water Temp Sender Austin Healey 6
R water temp bulb loose Austin Healey 27
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
Gundy Temp gauge on Mk3 Midget Spridgets 4
M water temp gauge Spridgets 7
A TR4/4A Tr4A temp gauge doesn't work Triumph 19
Sopwith_Camel temp Jaguar 8
T TR4/4A How hot at radiator neck when temp gauge is reading innthe middle Triumph 6
Got_All_4 TR2/3/3A Need a temp glass Triumph 11
