TR6 Coolant Temp Q
Govtslug
Member
My TR6 only gets to about 1/3 the way up the temp gauge unless I’m sitting in traffic on a hot day. Once I start moving it drops back to about 1/3 of the way on the gauge. I’ve changed the temp sensor and the thermost and there is no change. I wouldn’t worry about it, but the engine clearly runs better when it’s hot and the gauge is showing half way. I’m running a 180 degree thermostat, should I change to a 195? Do you think it will be too hot day? Anyone else had this problem? Thanks!
Govtslug
poolboy
It could still be the sensor...I know this one is puts the needle close to the middle of my gauge...but the main thing I think would be to find out what the actual temp is no matter where the needle points.
Govtslug
Govtslug
Member
Thanks. I might try a new sensor, they’re cheap. But the car seems to really prefer to run hot (middle of the gauge). Much less missing in the mid RPM ranges and just smoother overall. The problem is I can’t keep it in the middle of the gauge, it drops back to 1/3 as soon as I get out of traffic and get the RPMs up a little. Any experience with a 195 thermostat? And, the engine is freshly rebuilt with a new radiator, so everything should be clean inside.
Tom
Madflyer
I went from a 165 to a 185 thermostat and my gauge went from just below center to just above center ( 1973 TR6 ) Is it a OEM radiator or Alum.
Running cold is not normal but you have to check real temp try a meat thermometer at the radiator with cap off. Check number two: with motor cold remove cap and start motor you should not see any water flow until steam comes out that will tell thermostat is working normally
Govtslug
Govtslug
Member
I put in a 195 thermostat and it now goes to the middle of the gauge. And the most important part, the engine runs much smoother at that higher temp. I’m leaving it alone now, especially as we get into fall, it should be good.
Tom
6 TR2/3/3A electric coolant temp gauge in TR3... Triumph 6
N TR6 Desired TR6 engine coolant temp? Triumph 7
Jim_Gruber Coolant Leak / Temp Sensor in the block Spridgets 10
Stewart MGB Coolant temp sending location 75 MGB MG 3
S Spitfire Cyl head coolant hose fitting Triumph 1
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
T TR2/3/3A TR3 coolant hoses Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
K TR2/3/3A Radiator coolant level? Triumph 5
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
D TR2/3/3A Coolant tap on TR3 block Triumph 3
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
B All the coolant in the wrong place Spridgets 17
G TR4/4A Thoughts on my coolant Triumph 12
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
JFS Wedge Low Coolant Light Triumph 7
Boink Waterless Coolant - thread from the AH forum Spridgets 18
PatGalvin TR2/3/3A Coolant System Hoses Slipping Triumph 5
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
Jim_Gruber Replacing Spridget Coolant Spridgets 21
T TR4/4A Coolant in the oil - again. Triumph 18
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
P Coolant level indicator wrong? Jaguar 4
sparkydave Coolant hoses Spridgets 5
T TR4/4A Oh crud - coolant in the oil Triumph 33
W Waterless Coolant Austin Healey 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
RAC68 Waterless Coolant Austin Healey 29
B TR2/3/3A coolant expelled Triumph 14
Keith_M 1275 burning coolant Spridgets 20
S Coolant Loss Spridgets 32
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
M oil in coolant Austin Healey 16
M TR4/4A Coolant. Triumph 7
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
