TR2/3/3A Replacement of Engine Coolant Drain
Skellyt
Any thoughts on removing and replacing the coolant drain plug on the engine block of a TR3. The original is leaking through the plug body where the handle swivels to open and close the drain, so I purchased a replacement from Moss Motors. Has any one removed the drain without first removing the carbs. While it appears to a straight mechanical removal (drain screws into the engine block), the lack of working space may make the removal of the carbs necessary.
CJD
I’ve done it many times without removing other parts. The only issue is i bet money the replacement will leak out if the package. Goop it with thick grease and it will likely seal.
TR3driver
Great Pumpkin - R.I.P
Might be pretty tough, depending on how corroded the joint is and how fat your arms are. I have to take a fair amount of stuff off just to get my hand down in that area.
D Engine replacement. Rover / Land Rover 0
R BT7 engine gallery plug replacement during rebuild Austin Healey 3
W Replacement frame engine mounts for a 100-6 Austin Healey 4
Jim_Stevens Engine front mount replacement Triumph 3
M 76 Midget Engine Mount Replacement Spridgets 1
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
T TR6 TR6 engine replacement options ? Triumph 59
CraigLandrum Engine compartment replacement metal tags Triumph 2
J Engine Mount replacement Triumph 14
D Spitfire Engine Mount replacement in a Spit... Triumph 3
L Rocker Panel Replacement; Engine in or out? Austin Healey 26
L replacement engine number plate? MG 6
T MGB '79 MGB engine mount replacement question. MG 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
