tr6nitjulius
Non-technical, hands on method by Master British Mechanic Tracy:
Changed my belt last month in 15 minutes, without using jack, untightening cross member bolts, while '72 TR6 on jack stands, tranny in shop for rebuild. Tools needed long screwdriver or pry bar.
(1) Loosen alt/gen bolt
(2) Remove fan belt
(3) Move fan belt down over H20 pump
(4) Push fan belt down squeeze under cross member
(5) Pull fan belt up between crossmember & back of fan
(6) Once bottom of fan belt is free
(7) Squeeze bottom of fan belt between back of fan, steering rack & frame
(8) Pull fan belt out between front of fan & back of radiator. Reverse how to for re-install.
Tracy's experienced/knowledgeable Magic
(2) Remove fan belt
