TR6 TR6 engine replacement options ?
T
Tinster
I was wondering if anyone knows of a car engine
that might bolt onto an existing TR6 tranny.
Or one that might require just some minor
modifications to attach to the tranny. I do
know the engine mounts would be different.
I'm thinking maybe a small, reliable, V-6 that
I could pick up cheap at the auto graveyard.
Thanks, just thinking out loud. No, I have no interest
in going the V-8 route and all that a massive project like that entails.
regards,
d
BobbyD
kodanja
WHY DALE?
yours is so close
kodanja said:
WHY DALE?
:iagree:
And you'd be opening up a can of worms in terms of weight distribution, whether the bodywork will allow space for it to fit, the potential difficulties with cooling, routing the exhaust system, the effect of any power increases on the rest of the powertrain, possible difficulties in steering column placement, more braking needed to offset the more go, etc.
You've got to consider more than whether it'll just bolt in.
Quite a number of people have dropped V-8s into their Big Healeys to make "Nasty Boys" and the problems they've had to deal are likely to appear with any similar engine swap into a TR6.
I'm not a purist, but I'd think the problems and difficulties would reduce the appeal considerably....
T
Tinster
kodanja said:
WHY DALE?
yours is so close
<span style="color: #000099">Just thinking out loud is all.
I've got a nice looking, owner restored TR6,
that could give me great enjoyment if it did not
break down all the time. But it does. I think I've
taken the existing engine just about as far as possible--
way out here in the middle of the ocean.
I was thinking a V-6 engine from a small SUV might
work. And I could get it serviced anywhere on the
island. I cannot get my TR6 serviced anywhere except
by me. We've seen the disaster my attempts have brought!!!
Just pondering ways to get my TR6 to a state of
reliability so I can drive it up into the mountains.
regards,
d</span>
kodanja
I dont know about that,
I think you would be making a big mistake JMHO!
maybe its time for a Miata!
Brosky
Maybe it's time for a trip to PR with an exorcism team.................
DNK
Get it serviced on the island. A lot of shops WON'T touch a car like that.
LastDeadLast
tomshobby said:
If you would do something that drastic this is the best I have heard of, at least in my opinion.
https://www.bowtie6.com/engine.htm
Joe used a 60 degree v-6 and did a great job of it. It has turned out to be a great success.
Yes, but Joe is pretty handy with metal fabrication tools also. I wouldn't touch an engine transplant unless I met one of two conditions:
1. I was bloody rich and could pay someone to do it for me
2. I was someone that was skilled at metal fabrication. (or had a VERY good friend with the same skill)
Dale, I don't think your problems are mechanical in nature so I honestly think that an engine transplant would be a monumental waste of money. These TR engines are some of the simplest engines out there and for the most part are no more or less prone to failure than any other engine of the same era.
Plus, if you go with a more modern power plant, you'll be dealing with fuel injection.. and you think your ignition system is complicated? Just wait.
If you do feel this way, then I think you should consider a Miata or a Pontiac Solstice. I think you'd be much happier since it would never break down. But admitedly you would lose much of the character that draws people to these old cars in the first place. These troubles are things that every owner of a classic car deals with in one way or another, so you need to decide for yourself if this is the route you want to take. There will always be something that breaks or needs tweaking, thats just the way it is.
rchakr
I have endured the continuing saga of the crypt car for many months now, and I have not come this far, to allow any talk of an engine swap. Your admiring public 'demands' that you fix your car and drive your car. Best wishes, Bob H.
kodanja
When did you purchace your car Dale?
I've had mine for 3 1/2 years now, it's just been recently that I've been able to actually enjoy it on the road. I still have issues with my TR6 but is'nt that half the fun of owning these little devils....
tdskip
In terms of trouble shooting and problem resolution the farther away from stock you go the harder it will be to get help.
I believe you have an unresolved fueling issue, which has to be easier to fix than trying to swap in another engine....
For $400 you could have a new/rebuilt set of carbs with a STOCK linkage. Worst case sell your existing carbs and linkage and it will likely fund a "do-over".
Or, you could focus on your fishing until one of us can get down there to help you sort the issues....
T
Tinster
Just under three years of breakdowns/repairs
with 1700 miles driven in total .
Everything in the engine compartment is either
brand new or has been rebuilt professionally.
I was thinking an engine swap was an easy thing.
SUV engines from wrecked cars are now a dime a dozen
with the cost of gas so high.
I was just pondering ways to get my car operational.
A shame to see it parked in the garage.
thanks all,
dale
tdskip
Dale - I think we are all deeply empathetic over how you must be feeling right now. I'm not as familiar with the car as you are obviously, but it seems like you have sorted the floors, engine bay, suspension, interior and just about everything else except for the fueling issue.
Sometimes it is good to just walk away for a month and then pick it back up.
Key thing is to only change one thing at a time or it becomes really hard to isolate problems.
GeeBee1
Dale
You have <span style="font-size: 17pt"><span style="color: #CC0000">GOT</span></span> to be kidding me, next you'll be shipping dolls by USPS to the big fifty.
T
Tinster
GeeBee1 said:
Dale
<span style="color: #660000">Sorry ??????????????????????? Dolls ????? </span>
angelfj1
Dale, my friend: What makes you think that a transplant would be any more reliable. If what you have told us and what I know about the business practices in PR, where would you find a reliable shop who would/could perform the surgery?
I believe that your best option is to keep your shoulder to the wheel and fix what you have. Perhaps you need to modify your strategy and address ONE system at a time, then move on the the next, and so forth. BTW, what is the status of Amos right now? The last I had read was something that looked like a rich fuel mixture.
fja
p.s. when can I expect a reply to my PM? :devilgrin:
T
Tinster
angelfj said:
Dale, my friend:
Frank, I posted my response to your seat height question
in the Triumph forum as a "how to" maybe a week ago or so.
BTW- I WAS sorting out entire systems front to back. I had
multiple failures across systems and did not know it.
Ie- I replaced the entire fuel delivery system, a second time,
because I was not aware I had a failed dizzy condenser.
I had 75 miles or so on a new condenser when it failed. My bad.
I then also replaced almost all the ignition system not knowing
I had blown up the brand new condenser.
Right now? Clueless in Bayamon. Perhaps the car is operational?
Quien sabe? Crypty es El Coche de Diablo, seguro! Bien malo!
d
D TR6 Help with tr6 engine diagnosis Triumph 11
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
T For Sale Triumph TR6 N.O.S engine block [late] Triumph Classifieds 2
R For Sale TR6 Parts huge collection and Engine/Performance Parts Triumph Classifieds 0
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
Got_All_4 TR6 European specks on a 1970 TR6 engine Triumph 6
D TR6 Tr6 engine dimensions Triumph 2
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
M TR6 TR6 how the engine works Triumph 7
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
B TR6 TR6 Engine leaks, jacking questions Triumph 9
R TR6 TR6 engine rebuilt Triumph 52
SkinnedKnuckles TR6 TR6 Engine Bearings Triumph 12
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
hondo402000 Stag TR6 Engine rebuild in final stage, dyno date 7=22 Triumph 23
M TR6 Free TR6 Engine! Triumph 4
ScottTR6 TR6 74 TR6 Engine Bay repainting Triumph 16
hondo402000 TR6 Painting TR6 engine bay in progress[NOW] Triumph 14
hondo402000 TR6 TR6 Engine rebuild in progress Triumph 14
hondo402000 TR6 TR6 Engine pulling process Triumph 20
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
hondo402000 TR6 Pulling TR6 Engine Triumph 31
hondo402000 TR6 TR6 Engine rebuild and getting uneasy feelings Triumph 36
I TR6 69 TR6 engine suggestions - cause for burnt valve? Triumph 5
hondo402000 TR6 latest Part for TR6 engine rebuild Triumph 6
I TR6 TR6 engine rebuild suggestions Triumph 8
hondo402000 TR6 TR6 Engine Rebuild parts on order Triumph 30
kodanja TR6 TR6 Engine in Ct anyone? Triumph 11
TR6oldtimer TR6 The TR6 engine is now alive Triumph 4
I TR6 69 TR6 engine rebuilding basics advice Triumph 14
swift6 TR6 Teardown of a 150k TR6 engine... Triumph 4
M TR6 tr6 engine rebuild Triumph 6
Mike_Roe TR6 TR6 Engine Mods Triumph 8
TRnorwegian TR6 Japanes TR6 starter engine - good idea or bad? Triumph 21
T TR6 TR6 engine into TR4 Triumph 15
J TR6 best way to mount the TR6 on an engine stand? Triumph 3
glemon TR6 TR250/TR6 Engine Rebuild Question Triumph 7
TR6oldtimer TR6 Spray painting a TR6 engine compartment comments Triumph 26
T TR6 Does a TR6 need an engine to chassis ground strap? Triumph 16
N TR6 Desired TR6 engine coolant temp? Triumph 7
E TR6 TR6 Engine Re-Build Candidate? Triumph 11
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
AltaKnight TR6 TR6 engine "freshening" Triumph 2
E TR6 TR6 Camshaft Install - Engine In Triumph 10
C TR6 FWIW TR6 engine and transmisson weight Triumph 4
2wrench TR6 Rear engine seal installation '74 TR6 Triumph 1
