Engine front mount replacement
Jim_Stevens
Guys- is there anything that needs to be removed or loosened prior to jacking up the engine an inch to replace the two worn front mounts? Thanks, jim
RJS
Hi Jim,
Nothing else. I have a TR4A and have done this a few times (just a month ago to insert some large washers under the motor mounts to give me proper clearance b/t the fan hub and steering rack). Just watch two things. 1) use a piece of wood or a couple of 2 x 4s to evenly distribute the force of the jack across your full oil pan 2) just watch the upper rad hose connection as you jack. A couple of inches should be OK but, it can get rather "dicey" if you go several inches or more.
On side comment, I replaced my two front motor mounts a few years ago with HD mounts from BPNW and it completely transformed the feel of the entire car. So much NVH was gone it was a real unexpected benefit.
Bob
HarryL
Wouldn't it also be a good idea to slack off a bit on the bolts holding
the gearbox to the frame ?
Harry
In addition too the engine mounts
R TR2/3/3A TR3A front engine seal? Triumph 3
KVH General TR Damaged Front Engine Cover Spigot Triumph 4
KVH TR4/4A Front Engine Plate Curve Triumph 4
TulsaFred Front engine oil leak Spridgets 33
dklawson Sorry... Urgent Request for Friend - Marina Front Engine Plate Other British Cars 2
dklawson MGB Sorry... Urgent Request for Friend - Marina Front Engine Plate MG 3
Scotsman TR2/3/3A leaking front engine plate Triumph 4
Boggsy64 MGB Transmission engine mounts and front engine mounts MG 0
mt10flyer TR2/3/3A Front Engine Plate Triumph 8
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
Tim Tucker Front Engine Oil Galley Plug Triumph 10
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
Darrell_Walker Torque spec for front crank bolt [TR 4 cyl engine] Triumph 2
Brosky Sealing of Saddle Block in front of engine Triumph 7
2wrench I'ts about the front engine seal and RTV sealant Triumph 13
2wrench Re: Screw at engine front stopping oil loss Triumph 8
E TR6 TR6 front engine seal leak Triumph 11
Kirk_Fisher TR4/4A TR4 front fenders/engine bay Triumph 13
mbrooks 100 oil leak from front of engine Austin Healey 3
B Surgery on front of engine in BT7 Austin Healey 7
L General Tech Engine id Triumph 4
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
