I'ts about the front engine seal and RTV sealant
2wrench
'74 TR6
Installed the front engine oil seal. Couldn't find
specs on a requsite torque. Just cinched them down well.
Used Ultra Copper silicone gasket maker.
Tried to install new wood on either side. Wood split
and could not be used on one side. I reinstalled the
originals. They looked good and were cut to size. Also,
they appeared to be made from a plastic, possibly, but
not wood, in any case.
See pic:
This picture is showing the back side of the front engine
seal in the block. Notice a bit of the RTV (tan color) that
dried in place? Should I try to remove this? If yes, how?
Pic:
Thanks,
Opps.
I would try to remove it if accessible. One less thing to break away and clog journals. Razor blade, Xacto knife, anything that will gain access and cut.
Very important to remove any silicone from the inside of the engine to prevent clogs. That orange RTV is really high-temp stuff suitable for exhaust joints.
Permatex #2 non-hardening is more suitable for engine assembly. I avoid RTV for engine work - if you use it on the pan gasket, it can squeeze out inside the block - not good.
I assume by wood that you mean cork on the side of the saddle block. Or does the TR6 use wood?
I am about to this point on my Spitfire rebuild. My manual says to tighten the sealing block down to the front plate before you tighten the sealing block down to the engine block. They say that is why so mnay of these engines leak from the front.
Re: I'ts about the front engine seal and RTV seala
They do indeed use wood. I have to take my steel sealing block out to check the front bearing. Guess I will have to buy another sealing kit. What's a few more lbs.
Yeah, Peter, the 6's use wood. The wood that came in my kit broke into pieces
along the grain of the wood right away. Obviously, I didn't handle it right,
but never thought it would be so easy to split.
Put the old wood in, though, as I have said, it looks to be plastic...just how
it looks. Maybe 'cause it's oil-saturated. I don't know.
I will clean the existing silicone off the inside of the block to a more
acceptable level and change my sealant.
Thanks.
This is an eye open-er. So am I supposed to loose screw it to the block,
tighten down to the front plate, then come back to the block?
I do have a reference builing manual that never addressed this issue nor do I
remember reading anything in the Bently....of course, doesn't mean it isn't
there, just means I could have missed it.
Anybody know if there is this distinction between the Spit and the 6?
Your description is what I assume it means and is what I am going to do.
Snug it to the block (not too tight)then tighten the front. Go back and tighten down the saddle screws. I did not do this on my Mark I many eyars ago and I suspect that may be one of my leaks (there are so many).
Only other advice I'd offer up is to remember that on a TR6 BOTH the front sealing block AND rear oil seal housing are aluminum and the threads strip very easily. After pulling it all apart last week I now know why I had that oil puddle on the floor. The sealing block threads were stripped. I re-tapped them at 3/8" coarse and snugged the bolts down by feel. I was afraid to use my torque wrench. I used Ultra-Black on the timing cover, rear seal housing and oil pan. I'll let you know in another two weeks if anything leaks :smile:
Argh. Here's where the Hylomar is well appreciated.
Yes. And hylomar is recommended on the sealing block gaskets and as a coating on the wooden side wedges.
No distinction. It is the same on both.
Yes, as Ross says above, no distinction in Spitfire (or the Spit-sourced engine in my 1500 Midget for that matter).
But my last kit for the 1500 provided "rubber" blocks that I think were really neoprene (instead of wood).
These blocks were slightly too big and no amount of foul language would make them fit. :jester:
So I trimmed them down with an Xacto knife and used a fair amount of Hylomar.
No leaks since (25+ hours of racing), even after a 4 hour race with average RPM around 5500.
Well my trip to NAPA found no Hylomar. I did find assembly grease for the cam lobes.
R TR2/3/3A TR3A front engine seal? Triumph 3
E TR6 TR6 front engine seal leak Triumph 11
KVH General TR Damaged Front Engine Cover Spigot Triumph 4
KVH TR4/4A Front Engine Plate Curve Triumph 4
TulsaFred Front engine oil leak Spridgets 33
dklawson Sorry... Urgent Request for Friend - Marina Front Engine Plate Other British Cars 2
dklawson MGB Sorry... Urgent Request for Friend - Marina Front Engine Plate MG 3
Scotsman TR2/3/3A leaking front engine plate Triumph 4
Boggsy64 MGB Transmission engine mounts and front engine mounts MG 0
mt10flyer TR2/3/3A Front Engine Plate Triumph 8
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
Tim Tucker Front Engine Oil Galley Plug Triumph 10
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
Darrell_Walker Torque spec for front crank bolt [TR 4 cyl engine] Triumph 2
Jim_Stevens Engine front mount replacement Triumph 3
Brosky Sealing of Saddle Block in front of engine Triumph 7
2wrench Re: Screw at engine front stopping oil loss Triumph 8
Kirk_Fisher TR4/4A TR4 front fenders/engine bay Triumph 13
mbrooks 100 oil leak from front of engine Austin Healey 3
B Surgery on front of engine in BT7 Austin Healey 7
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
