Hey Guest! BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF helpful, appreciate no pop up ads, and you want to ensure we stay online - Please support us with an "optional" low-cost (less than many car club dues) member upgrade. There are some benefits to upgrading!
Nothing else. I have a TR4A and have done this a few times (just a month ago to insert some large washers under the motor mounts to give me proper clearance b/t the fan hub and steering rack). Just watch two things. 1) use a piece of wood or a couple of 2 x 4s to evenly distribute the force of the jack across your full oil pan 2) just watch the upper rad hose connection as you jack. A couple of inches should be OK but, it can get rather "dicey" if you go several inches or more.
On side comment, I replaced my two front motor mounts a few years ago with HD mounts from BPNW and it completely transformed the feel of the entire car. So much NVH was gone it was a real unexpected benefit.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
