Spitfire Engine Mount replacement in a Spit...
desmo900rider
Member
I have a broken engine mount in my 79 Spitfire, and I am going to be replacing both front mounts tonight...It looks fairly easy...I am assuming that I just put a floor juck under the engine and jack it up a bit to get the weight off the mounts, and swap them out? Any tips or tricks that anyone has?
Thanks!
Mike
jsneddon
yup. that's about it. wood under pan, lift her up, swap 'em out, open beer.
desmo900rider
Member
Wow, what a diffeerence...the car had a broken, as in broken in 2 pieces, passenger side engine mount when I bought it a month or so ago, now with 2 new mounts its a whole new car!
Jim_Stevens Engine front mount replacement Triumph 3
M 76 Midget Engine Mount Replacement Spridgets 1
J Engine Mount replacement Triumph 14
T MGB '79 MGB engine mount replacement question. MG 0
J TR2/3/3A Engine mount Triumph 5
M TR6 TR5/6 Engine Mount/Chassis Brackets Assistance Please. Triumph 2
Bugeyze Engine mount advice please Austin Healey 9
G Wanted Packing pieces on rebound rubber engine mount Austin Healey Classifieds 0
G Packing pieces on rebound rubber engine mount Austin Healey 5
Sarastro TR4/4A Engine mount questions Triumph 7
RCarr BN1 Engine Mount rubber parts Austin Healey 4
D TR4/4A square engine mount washer necessary? Triumph 6
TulsaFred Engine Install motor mount question Spridgets 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
Kleykamp Transmission/engine mount removal Triumph 4
brgrmyster GT6 GT6 Engine Mount "Spacers" - What's the Purpose? Triumph 2
L Engine Mount Thickness for Bugeye, etc. Spridgets 1
S T-Series How do we mount a TD engine on an engine stand? MG 7
glemon TR5/TR250 TR250/6 engine mount Triumph 2
K clutch slave engine mount Triumph 13
J New engine mount set up Austin Healey 0
Tinkerman Engine Mount Spacers ?????? Triumph 10
J TR6 best way to mount the TR6 on an engine stand? Triumph 3
kyreb1862 77 RB Engine Mount Problem MG 1
B TR6 TR-6 Engine Lifting Mount Bolts - Leaking? Triumph 12
David_K Painted engine mount buffers Austin Healey 3
Bruce Bowker Alfa Side mount engine Other Cars 4
mrv8q TR2/3/3A TR3 Water pump/Engine mount advice Triumph 2
L General Tech Engine id Triumph 6
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
