TR6 TR5/6 Engine Mount/Chassis Brackets Assistance Please.
malbaby
Planning install of 6cyl TR engine into my TR4A project car and require the brackets that are welded onto the chassis.
OR....accurate dimensions to make my own.
Gliderman8
Will see if I can get some dimensions for you tomorrow.
Gliderman8
Malbaby.... here's the dimensions that I came up with in order to make the TR6 brackets. If I missed anything or something does not look right just let me know and I'll get/verify a measurement.
I did not get any dimensions for the hole size/placement. I would use the rubber motor mount that attaches to the engine as a template to place the holes.
Hope this helps...
EDIT..... I reposted the drawing since a dimension was left off but is now updated
Finished Mount
Drawing detail
W TR6 tr5 tr6 engine specs Triumph 3
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR5 Factory Parts Manual on CD/ROM - 1967 to 1968. Triumph Classifieds 0
S For Sale Triumph TR5 Factory Workshop Manual on CD/ROM - 1967 - 1968 Models. Triumph Classifieds 0
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
Number_6 TR5/TR250 First TR5 for sale Triumph 1
hondo402000 TR5/TR250 TR5 gearbox rebuild on youtube Triumph 0
arizonamike TR5/TR250 TRGB FUN AT LE MANS IN A TRIUMPH TR5. Triumph 0
tr6nitjulius TR5/TR250 ProtoType TR5? Triumph 3
angelfj1 TR5/TR250 Pricey TR5 Triumph 16
T TR6 TR4/TR5/TR6/TR250 parts still available Triumph 4
apbos TR5/TR250 Triumph TR5 tub Triumph 1
Russ Austin TR5/TR250 New TR5 Thread Triumph 3
T TR5/TR250 TR5 Triumph 78
F TR5/TR250 Ebay TR5 deja vu all over again Triumph 18
PeterK TR5/TR250 Stolen TR5 Triumph 5
D TR5/TR250 Triumph TR5 Triumph 15
G TR5/TR250 LHD TR5 Triumph 7
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
