replacement engine number plate?
Lonnie
My machine shop lost my engine number plate. Is there any place I can get another one? I have the number written down.
Lonnie
Frazier
Victoria British has the blank engine plate, Part # 9-0859, but I assume you would have to take it to a local shop to have the numbers added.
Frazier
Frazier
Just curious, did you have the engine block soaked? If the ID plate was not removed, it was chemically destroyed.
Frazier
Mickey Richaud
[ QUOTE ]
If you are interested, Clarke Spares and Restorations fabricates engine ID plates from the information you supply. He stamps them with the correct raised letter as per original.
https://www.clarkespares.com/
[/ QUOTE ]
They did mine, and it came out looking just like "the real thing." They even have the correct rivets to install them.
Mickey
D Engine replacement. Rover / Land Rover 0
R BT7 engine gallery plug replacement during rebuild Austin Healey 3
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
W Replacement frame engine mounts for a 100-6 Austin Healey 4
Jim_Stevens Engine front mount replacement Triumph 3
M 76 Midget Engine Mount Replacement Spridgets 1
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
T TR6 TR6 engine replacement options ? Triumph 59
CraigLandrum Engine compartment replacement metal tags Triumph 2
J Engine Mount replacement Triumph 14
D Spitfire Engine Mount replacement in a Spit... Triumph 3
L Rocker Panel Replacement; Engine in or out? Austin Healey 26
T MGB '79 MGB engine mount replacement question. MG 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
T TR2/3/3A Replacement radiators Triumph 8
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
F TR4/4A Replacement air filter for SU HS6 Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
A MGB MGB 1974 windscreen centre rod replacement MG 5
B Poor quality BE replacement spring boxes Spridgets 0
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
B TR6 Fuel tank replacement Triumph 0
S MGB clutch replacement MG 7
S Wiring Harness Replacement Spridgets 1
JPSmit Not something you see everyday - a warranty replacement Spridgets 1
M 1972 Midget Seat Belt Replacement Spridgets 4
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
T TR2/3/3A tr3 front carpet replacement Triumph 5
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
EWD TR6 Dash Pad Replacement Triumph 3
R TR6 fan shroud replacement Triumph 5
C Replacement wheels Rover / Land Rover 1
B TR4/4A Floor pan replacement Triumph 4
DrEntropy MGB Replacement starter MG 7
