    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR2/3/3A TR-3 water temp guage
AweMan
Ok I finally located a Smith/Jager water temp guage minus the capallary tube for my TR-3
I know that the tube can be replaced and have even went as far as to do an inquiry.
I was quoted $225.00 for a rebuild, replace the capillary tube and calibration.
Question one is. ..... is this a reasonable price?
Question two is. ..... In the Moss Parts magazine the diagram shows the capillary tube going around the heater assembly is this necessary? If so .... does anyone have any idea how long the capillary tube should be in order to properly install it like the original factory installation?
Question three is ........ any suggestions as to alternate places to inquire for this guage rebuild?
Kerry
1956/7 Tr-3 Smallmouth TS 12909 L.O.
{manufactured in 56 and titled in 57 what do I call it? A 56 or a 57 ?}
I had mine rebuilt by Nisonger a number of years ago. I don't recall the cost but I do remember that I thought it reasonable at the time. I don't know how expensive the tube might be, but I'm sure Nisonger could provide it.
There's a place in the SoCal Valley that rebuilds them; they're listed in the Moss catalogs. 2 years ago, they rebuilt the one in my '59 TR3A. Since they were only 10 minutes away from my work, they were a no-brainer to try out... And it works great. ISTR is was $150 or $165; they supplied a new capillary tube. I recommend them!
I have seen a procedure for repairing these at home -- a real 'Mr Wizard' project with ice & ether. Donor for the tube is a capillary gauge supposedly available at PepBoys.
Too involved to detail here but some Googling or a look in the Forum archives should reveal the process.
BTW -- that tube is a looong sucker. Yes, they ran it around the heater but I know of no reason why this is necessary.
Check the Knowledge Base
for an idea!!!! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
You can repair this gauge yourself for less then $20. I've done it and it works. I got a donor capillary temp guage from Pep Boys for $16. I then followed the procedure at this site. Essentially you use the tube and ether bulb from the donor , and with a sleeve, you solder it onto the old gauge. To keep the ether in the bulb, it's put into a pot that has ice, salt and some water. I measured the temperature of the ice slurry, and it was about zero degrees F...cold enough to keep the ether in. The gauge works fine, and is dead on accurate.
Edit: Here's a link to the thread from last year when I found the repair procedure and decided to try it.
Art, Excellent link. Don't know how I missed it before. I have the original temp guage from my conversion article. In the intrest of originality I'd really like to keep a capillary tube setup. I will definatly be trying that procedure.
Kaizen!!! (continuous improvement) Might have ro re-do the KB article.
$380.00 Is a little pricy for me! I`ll be trying the "Home remedy" repair also. Thanks for the info too !
The car currently has a working SW guage in it, Possibly a donor.
Now if I could just find the grill surround trim.
Kerry
56 Tr-3 TS 12909 L.O.
jlaird Water temp/oil pressure guage Spridgets 3
martx-5 Water Temp Guage Repair Triumph 2
shadowfever Water temp Spridgets 9
Editor_Reid Water Temp Gauge Austin Healey 5
RickPA Water temp gauge reads low Austin Healey 6
F TR2/3/3A Water Temp Triumph 10
vette Threads for the Water Temp Sender Austin Healey 6
R water temp bulb loose Austin Healey 27
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
M water temp gauge Spridgets 7
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
luke44 TR2/3/3A TR3 Water Temp Sensor Installation Problem Triumph 37
BOBBYR Water Temp Gauge Austin Healey 5
M 1275 need to install water temp bulb. Spridgets 6
F Water Temp Question Spridgets 2
luke44 TR2/3/3A TR3 Water Temp Gauge Core Triumph 14
L Water temp sensor placement [secondary] Spridgets 7
G Broken water temp gauge Austin Healey 14
pjsmetana Mechanical Sunpro Oil/Water Temp Gauge Triumph 5
drooartz Pluging water temp hole in head Spridgets 9
R mech. water temp gauge repair? have you tried this Spridgets 4
19_again connection at water temp gauge MG 7
C Another water temp line question Austin Healey 3
ronzet Water Temp Sensor Fitting on Radiator Austin Healey 10
AUSMHLY Water temp, hot? Austin Healey 8
JPSmit next dismantle question - water temp sender Spridgets 10
F Removing the Oil Pressure water temp clock MG 2
T Repairing a dual water temp / oil gauge Spridgets 1
M XJS Fuel Injector, Air Temp Sensor, Water Temp Sensor Harness Connector Replacement Jaguar 0
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
D Water Valve Connection Austin Healey 4
T TR2/3/3A Moss uprated water pump Triumph 6
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A Water pumps/head cooling Triumph 22
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
A MGB Stuck water temperature sensor MG 26
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
