    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
connection at water temp gauge
19_again
Had to destroy engine end of temp cable when pulling engine, necessitating replacement and connection at gauge is tight as well. Is the cable held in place by the two screws at bottom of gauge case? It's the '67 B.
Mike
Thanks Dave,
I knew it wasn't elec, but thought it had an end similar to the sensor at the block. Those two screws are directly in line with the end of the tube, and thought a simple fix was an option. HAHAHAHAHAHA.
Hafta "thread" the whole thing from the dash opening thru the firewall to the t'stat housing. It's one piece from gauge to bulb.
I suggest Nisonger as the rebuilders. Not cheap, but it'll WORK in the end.
And don't crimp the tube while you thread it through. Plan the route before installation. Make a loop in the tube so that vibration/engine movement doesn't fracture it. Strap it to other soild points such as heater pipe, gas line, or whatever is available.
Jim
If you're a little bit handy, you can repair these capillary temp gauges folllowing the instructions here. I've repaired several this way including the one in my TR3.
The problem is that the nut had to be severely molested using a plumber's wrench after failing to yield to Heat, PBB, Freeze-Off and prayer. But the unit itself is fine. At this point the plan is to grind it back to a two sided shape that will work with a wrench and risk the concourse judge's ire. If that left eyebrow goes up more than a quarter of an inch, I hear I'd lose 32 points. I'd be devastated.
Fuss it to a shape you can get a wrench onto and use anti-seize liberally!
...and poo on th' judges. :smirk:
D Water Valve Connection Austin Healey 4
Sopwith_Camel MGB missed connection MG 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
T TR6 Air vent rod connection Triumph 1
D 62 tri-carb fuel line connection Austin Healey 10
S TR2/3/3A clutch pedal connection hole Triumph 9
D TR2/3/3A Main ground connection Triumph 2
B Outer steering column connection to the steering box Austin Healey 6
warwick-steve Rear Brake cylinder connection Austin Healey 12
D TR2/3/3A Vacuum connection at Carb Triumph 23
69MGC MGC What are these connection wires? MG 6
I Spitfire 78 spitfire carb connection help Triumph 8
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
F What to do with breather pipe as my new air filters have no connection for one? Austin Healey 31
K TR2/3/3A Remote starter to alternator connection.... Triumph 10
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
C Overdrive throttle switch rod connection picture Austin Healey 3
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
J 1/4" BSPP Fuel Line Connection, Hose from Steel Line to Carb Austin Healey 2
M ignition coil high tension lead connection Spridgets 10
germanmichel BT7 Steering Box - Tube connection Austin Healey 3
Lukens TR2/3/3A Petrol pipe connection to tank. Triumph 9
R TR2/3/3A TR-3 Fuel Tank Outlet Connection Triumph 6
rggav female 1/2-20 to 5/16 hose barb for fuel line connection MG 5
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
M Fuel Line to Tank Connection Question [pics] Triumph 2
TulsaFred Float bowl to jet connection leak on HS2 Spridgets 8
B BN7 Fuel tank/line connection Austin Healey 3
W help identify a wire connection Triumph 5
M Connection the Engine to Gearbox [pics] Triumph 27
af3683 Choke Cable Connection to Rod Assembly Fork Triumph 7
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
richberman brakes line connection question Austin Healey 18
W HIF44 carb... throttle cable connection Spridgets 9
R ARP head and connection rod studs? Spridgets 15
davester Loose manifold to exhaust connection MG 3
JPSmit Family Connection Spotted Spotted 1
Norman Throttle connection Austin Healey 2
D TR6 Looking for some TR6 wiring connection info Triumph 15
Westfield_XI Denso alternator connection question Spridgets 5
drooartz Choke cable connection? Spridgets 8
D Spitfire Elec wire connection for wiper - 71 Spitfire MkIV Triumph 1
texas_bugeye Alternator Connection Spridgets 1
Nelson Choke cable connection? Spridgets 5
jdubois TR2/3/3A TR3A fast idle cam connection? Triumph 26
19_again choke connection 67B MG 9
George Zeck Turn Signal Light Bulb & Connection ..... Spridgets 1
DART Speedo to Trany connection Austin Healey 2
bluemiata90 TR2/3/3A TR3 OIL PRESSURE LINE CONNECTION---HELP Triumph 4
R Coil connection question Spridgets 22
