help identify a wire connection
wong
1972 tr6 US model
I was fixing the throttle bushing and noticed a female/male connection is disconnected. This is about 12 inches right under the servo unit assembly(master cylinder) . The female side has 2 connection leads but it only has one wire. The other wire I am asssuming it is ground. I measured the voltage from this one wire lead to the ground is about 7.1v. The male side is attched to an odd shape part that has metallic hoses/pipes that go to the brakes(i think they going to the brakes, not 100% sure). I don't know what this connection is for and not able to tell which hole is positive or negative on the male side because the female is no loner fit into the male side for whatever reason.
I have checked mossmotor under brake system and was not able locate or identify this connection and part. Please help identify this connection, what the connection for and which side is positive on the female side(the end that attached to the metallic part that has hoses/pipes go to the brake.
Thanks.
M_Pied_Lourd
Sounds like it might be the PDWA switch. Is this what it looks like?
Cheers,
M. Pied Lourd
hondo402000
if you ground the wire a light on the dash should come on too, thats if previous owners have not cut wires under the dash
Hondo
W
wong
much thanks.
I have been driving this car for over a month now and there is no sign of brake related fluid leaking. Is it safe to drive the car without having this connection? I am not even sure if there is a warning light in the dash or not. Will have ground the wire to see.
TR3driver
Great Pumpkin - R.I.P
The 7.1 volts probably indicates the wires & dash lamp are good. The oil light will also go out when the PDWA wire is shorted to ground.
hondo402000
if you dont have any brake leaks you should be ok to drive and that PDWA device is a shuttle so if you loose front or rear brakes it shifts a plunger to one side and gives you warning lamp
Hondo
R help identify this wire wheel Austin Healey 11
P Please help identify this tourer Spotted 13
apbos Help Identify this car chassis Racing 20
AngliaGT Help Me Identify These Parts Jaguar 6
N Help to identify parts - BT7 Austin Healey 7
N Please help identify this car Spotted 22
C Help me identify this Heater Box, Please Austin Healey 7
C Help me identify the engine Austin Healey 16
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
N Can you help identify these shock absorbers? Triumph 6
P please help identify these parts Austin Healey 8
E Help Identify This Part..... Spotted 13
M BN2 Please help me identify this bolt Austin Healey 6
angelfj1 TR2/3/3A TR3A - help to identify this hole. Triumph 11
QuickSilver Help Identify This B MG 22
A Spitfire luggage rack for a MK3 spit [help] identify Triumph 8
vping Help Identify this Wheel MG 11
vping Help Identify this hardtop please MG 21
Johnny Help Identify BJ8 rear mufflers Austin Healey 14
vping Help Identify this part. Jaguar 2
Stig Help identify this part. Triumph 2
walt Help identify renault engine in 71 S2 europa Lotus 1
bighly Please help me identify this tonneau cover MG 10
bighly Please help me identify this tonneau cover Jaguar 1
bighly Please help me identify this tonneau cover. Austin Healey 1
TR4 Speedo Help Needed ! Please Identify this clip !! Triumph 5
vping Please help identify this steering wheel Other British Cars 4
P can anyone help me identify my mini? British Motor Corp 11
T Help Identify Bolt?? Triumph 4
Webb Sledge Help me identify this healey Austin Healey 19
A Help me identify my unit MG 15
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
