Help me identify the engine
christophe
Looking for help identifying the engine that came out of the 1960 Healey. I believe it is a 1967 BJ8 engine, but that is about all i know. The tag is completely rusted off minus the first three characters, which are 29K.
-The casting number seems to indicate that the block was made in December of 1966, or that is my guess. Is that correct?
-No idea what the casting LC3 means
Any help with identifying the date and exact specs of engine would be greatly appreciated. Late 66 build date for a 67???
AH100M
29K indicates a BJ8 (3000 Mk III) according to Clausager's "Original Austin-Healey. Numbers went from 101-17631.
DerekJ
The dip stick position is higher up on the engine for the BJ8. For the earlier cars its tucked down by the distributor. Thats the most obvious external way to tell the difference.
C
christophe
So the tag on the engine at in time had the VIN or some portion of the VIN stamped into it? Is that how you tell if one of these cars has its matching engine? If that is the case, maybe i should start looking around for the original engine to this car.
Deleted member 8987
The chances of finding the original engine are little and none. Finding a correct engine is do-able.
Guesses are the "original" had enough damage it was not economically repairable, or they wanted more power. Depending on when it was done, original is most likely in the bottom of a landfill somewhere.
Dave
CLEAH
No, the engine and commission numbers are not the same. In the case of a Healey, "numbers matching" just means that the numbers listed on the Heritage Certificate match the numbers on the car.
C
christophe
Ok! Thanks for the responses. We are sticking with what we have. The engine ran fine, minus having some run on problems when it was shut down...most likely just needed minor tuning.
AH100M
Depressing the clutch (rather than being in neutral with the clutch out) when you shut it down may put enough drag on the engine to stop it. Or shut it off in 4th and stall it (with your foot on the brake!). Some engines can't be tuned to not run-on, some can. I remember my friends brand-new BJ8 would sometimes run-on especially after a hard drive.
I'm going to go out on a limb and say one of the most common causes of run-on is idle set too high. On my mostly stock BJ8 engine an idle over 800RPM will run-on consistently, below that it's uncommon. Fast cams, etc. may change the equation.
C
christophe
Good to know. Im not sure where the idle was actually set since the tach didn't work below 1,000 rpm. Im sure things were just out of adjustment. The only carburetors i have ever worked on have been 4 barrel style holleys and Carter units. Right before tear down I tinkered with the carbs for a few hours after reading the manual. it was running better, but as soon as it was to operating temperature it still had the run on problem. That and it would flood badly and not want to restart. Hopefully all of these issues will get sorted out during the restoration.
CLEAH
Christophe, maybe you had run-on problems because that strange thingy was stuck in the intake! Now that it is gone, it may be fine!
Keoke
IF the engine runs hot this will contribute to run on also
Deleted member 8987
Yes. Car and ENGINE. Finding "original engine" would be next to impossible. Dummying up an engine tag would be a bit easier, but not as honest.
I thought the Heritage Certificates had engine numbers, as the Jag ones do, and yes, they do:
https://www.heritage-motor-centre.c...tificates/car-traced-with-chassis-number.html
So, first order is to get a certificate for your chassis number, and go from there.
Dave
BJ8Healeys
Christophe, you definitely have a BJ8 engine (29K series), but once that serial number tag is gone or illegible, there is just no way anymore to determine exactly which engine it is or which car it came out of. The serial number plates are aluminum and will dissolve in the hot tank chemicals used to clean the block during a rebuild. The tags are removable, but it isn't obvious how to get the rivets out and most people don't think about the tag when they have their engine rebuilt. Unfortunately, there are just a LOT of engines that have lost their serial number tags. Had the number on your engine been legible, I could have told you which car it came from if it mattered to you.
Phase 1 engines (up to engine /H278, approximately chassis 25450) had the dipstick tube lower on the block than Phase 2 engines did.
BJ8Healeys
I forgot to comment on your guess as to the build date of the engine. If your date is based on the number 12 B 766, that is the BMC part number of the engine block casting, not a build date or code.
C
christophe
Thanks for all the comments. Great information. Hopefully this engine will only need minor touch ups and be good to go for many years.
Does anybody have the specs for the BJ8 engines? Valve lash setting, if different from other models..cam specs such as lift, duration, and LCA, bore and stroke, etc.
AH100M
I don't know of any source that has more information than the "General Data" section of the factory shop manual.
walt Help identify renault engine in 71 S2 europa Lotus 1
P Please help identify this tourer Spotted 13
apbos Help Identify this car chassis Racing 20
AngliaGT Help Me Identify These Parts Jaguar 6
N Help to identify parts - BT7 Austin Healey 7
N Please help identify this car Spotted 22
C Help me identify this Heater Box, Please Austin Healey 7
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
N Can you help identify these shock absorbers? Triumph 6
W help identify a wire connection Triumph 5
P please help identify these parts Austin Healey 8
E Help Identify This Part..... Spotted 13
M BN2 Please help me identify this bolt Austin Healey 6
angelfj1 TR2/3/3A TR3A - help to identify this hole. Triumph 11
QuickSilver Help Identify This B MG 22
A Spitfire luggage rack for a MK3 spit [help] identify Triumph 8
vping Help Identify this Wheel MG 11
vping Help Identify this hardtop please MG 21
Johnny Help Identify BJ8 rear mufflers Austin Healey 14
vping Help Identify this part. Jaguar 2
Stig Help identify this part. Triumph 2
bighly Please help me identify this tonneau cover MG 10
bighly Please help me identify this tonneau cover Jaguar 1
bighly Please help me identify this tonneau cover. Austin Healey 1
TR4 Speedo Help Needed ! Please Identify this clip !! Triumph 5
vping Please help identify this steering wheel Other British Cars 4
P can anyone help me identify my mini? British Motor Corp 11
T Help Identify Bolt?? Triumph 4
R help identify this wire wheel Austin Healey 11
Webb Sledge Help me identify this healey Austin Healey 19
A Help me identify my unit MG 15
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
