Spitfire luggage rack for a MK3 spit [help] identify
AK_ED
well the title says it all i just picked up this deck lid and rack for 20.00 and was wondering who or what brand it is. I have googled around a bit and cant find anything out. Thanks and i hope some of you have seen it before.
cheers ed
A
AK_ED
heres another pic of it. also is there away to post more than one pic per post?
thanks ed
the rack bolts under the hinge area.
WedgeWorks
My first guess is always Amco.....but you will need to do some serious searching online through old pictures of archives. There were so many accessory manufacturers back in the days.
HerronScott
I would guess Amco as well as it has a similar design to the one for the TR4 which bolted at the hinge and license plate.
Scott
Andrew Mace
:iagree:, Scott! I had an AMCO rack just like that on a Mk3 Spitfire. I'm not 100% positive, but I think that the Spitfire and TR4 actually used the same rack.
A
AK_ED
hey guys
thanks for the thoughts on the rack, do you guys have any sites that have good old photos on them. i have spent alot of time with no good results as of yet. i will try a search using the words amco and see what i get.
cheers ed
<span style="font-weight: bold">just did a search using amco and im getting closer </span>
p.s. the car this cam off of is headed to the crusher due to a frontend impact. i have stalled the owner till april so i go and get it before then so i can part it or save it as there seems to be no frame damage. i will post a thread when i get pics and see if its worth saving. its a 66 i think.
Andrew Mace
Here's a smallish image of a US accessory catalog page, and it shows "your" rack and the somewhat similar aluminum version.
If it's relatively rust-free and complete, I'll wager it's worth saving! Bonnets aren't THAT hard to come by (I've a couple Spitfire 4/Mk2 bonnets myself that are definitely salvageable), and those frames are not difficult to straighten if any damage to same is confined to the front part.
A
AK_ED
i dont think the frame is bent at all, the damage seems to be above the frame the radiator didnt even get damaged, ill look it over after the snow melts and see what its all about,
thanks for the link i blew it up so i could see it and that is it i also have the over rider bars front and rear as well as the knock off wheels, someone checked all the boxes off on this one.
anyways back to work on the engine bay clean up.
cheers ed
roscoe Low-Budget Luggage Rack Austin Healey 27
Prof. T Wanted Luggage Rack Triumph Classifieds 13
N Wanted Amco Luggage Rack Triumph Classifieds 2
R Installing Sprite Luggage Rack Spridgets 9
R Luggage Rack for 62 Sprite [Square Body] Austin Healey 1
W Wanted Bolt on luggage rack Triumph Classifieds 4
K For Sale MG Midget luggage rack Spridgets Classified 2
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
M Austin Healey Luggage Rack For Sale - revised Austin Healey 4
toysrrus TR2/3/3A OEM TR3 Luggage Rack Triumph 7
angelfj1 TR2/3/3A NOS Luggage Rack Triumph 3
D TR6 Luggage Rack Triumph 13
D Bugeye Luggage Rack Spridgets 0
S luggage rack Triumph 4
L Luggage rack British Motor Corp 3
kyreb1862 Luggage Rack Foot MG 4
I TR6 TR6 luggage rack - repair help Triumph 13
justin_mercier 4 month search over! Luggage rack obtained. Triumph 9
Brosky New deck lid and luggage rack Latest Triumph 21
Gliderman8 Replacement Amco luggage rack Triumph 12
jvandyke luggage rack interchangability Spridgets 0
1 Luggage rack: Which version is "correct" for a 60 Spridgets 7
TonyPanchot Boot luggage rack Triumph 6
toysrrus "WANTED": LUGGAGE RACK FOR MY `59 BUGEYE: Spridgets 9
Lin Luggage Rack Boot Lid Shield Austin Healey 18
S Luggage Rack Straps Triumph 8
Jer Luggage Rack Spridgets 24
gsalt57tr3 TR2/3/3A TR3 [pre TR3a] Luggage Rack Triumph 7
abarth69 Luggage Rack Austin Healey 13
N Fastners for trunk mounted luggage rack? Triumph 8
Lin Cape International luggage rack Austin Healey 1
Team_Sprite Bugeye Luggage Rack, Speedo & Tach Jewell Inset Spridgets 30
I Wooden luggage rack Triumph 3
TRMark Luggage Rack Triumph 4
Ed_K Luggage Rack recommendations Austin Healey 11
A luggage rack? Austin Healey 6
JoeC TR6 TR6 luggage rack origin Triumph 5
Simon TR4a Opinions on luggage rack Triumph 13
C Luggage rack differences? MG 3
B Luggage rack placement MG 7
W Luggage Rack MG 10
W Anywhere I can get a luggage rack? MG 2
Mickey Richaud MGB MGB Flat Bar Luggage Rack MG 13
A TR6 removable luggage rack f/TR6? Triumph 2
MarshgrassA TR4/4A Vinyage luggage for TR4A Triumph 6
brgrmyster Proper finish on luggage floor angle assembly? Triumph 0
brgrmyster GT6 GT6 Luggage Floor Panel Thickness Triumph 25
d_valentino Austin Healey 100 "Fitted Luggage" Austin Healey 6
JPSmit Show & Tell - tonites craft, luggage straps Spridgets 11
