Another water temp line question
Coastalman
Hi to all,
I am taking the temp/oil gauge out as part of replacing the dash and have run into a problem. In preparation to loosing the nut at the head, I soaked the nut with PB Blaster and cut a slot in a spark plug socket to let the line go into the socket and then slide the socket up on the nut. All that went well and I was able to start loosening the nut. The nut turned about six flats and then has started binding the line. When turning the nut, at this point, the line has started trying to turn also. I am afraid to put very much pressure on the nut and force the line to twist which might break it. Is there a way to free the line from the nut so I can continue to remove the assembly?
Thanks,
Charlie
Ed Kaler
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I am afraid to put very much pressure on the nut and force the line to twist which might break it.[/QUOTE]
Charlie, just make SURE that guage is free to turn in the dash. Then just do ONE full rotation of the nut whilst turning the capillary tube. Kind of a PITA but will work.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Is there a way to free the line from the nut so I can continue to remove the assembly? [/QUOTE]
After it is out and with either vice jaw covers or a double folded shop rag put in the vice and GENTLY clamp the adaptor (end) nut with tube in the air. On and off FOAM your penatrating aersol into the top "slot". Gonna have to do for a day or two. Then with rag around the "bulb" try to rotate it with plyers GENTLY!! Did I say GENTLY?!?
Most importently is TAKE your TIME!! Do NOT hurry!! :hammer:
:cheers:
Ed
Ed_K
Hi Charlie,
Once you get it apart, I would certainly suggest slathering no-seize around the end before putting it back together. That is two different metals in close contact if I remember correctly and you live close to the salt air.
Ed
C
Coastalman
Ed and Ed, Thanks for the great advice. I guess that just proves that two "Eds" are better than one. Sorry, I could not resist that one. I'll get the guage loose tomorrow and do the rotation as I loosen the nut.
Charlie
jaybird Puttin' in another water pump! MG 22
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
J Another Healey back on the road....for now. Austin Healey 8
D TR6 Another Newb Question Triumph 10
