Convert BJ8 exhaust to single silencer
NIB
I have a BJ8 ph2 with stainless double silencer system, as original. If i want some more noise, can I somehow buy parts to convert it to a single silencer system with outlet in the rear left or do I have to buy a completely new system?
Ed_K
Yes NIB,
Go to a good muffler shop where they can custom bend exhaust
pipes and have them make you a couple of pipes that connect to the ends of the front silencers and then run out like this photo.
Ed
Keoke
Hi ED that is good advice. However, my experience is, most muffler shops do not have SS the ability to bend SS tubing or do stainless steel welding.
You might want to bring the end pips out further to avoid discoloring the fender(wing). I've seen chrome stain from exhaust so I can only imagine what will happen to paint.
N
NIB
Seems like AH spares has a complete system, has anyone tested that?
Manufactured especially for A.H. Spares by Double S exhausts these performance exhausts are a straight through system which makes the two rear silencers redundant creating better ground clearance. This also provides increased exhaust gas flow. Made from high-grade stainless steel this system will definitely give you a performance and sound upgrade. Comes complete with down pipes.
showpicture.aspx
bob hughes
Mostly, side exhausts pop out just in front of the rear wheel not behind it. If you have the right size pipes at the muffler under the seat, it is just a matter of buying in a side exit that fits directly to the muffler.
Bob
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
R 948 convert to 1275 info Spridgets 13
Tiger2Dan For Sale Convert your 4 cyl to a V6 Other British Classifieds 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
TRMark TR4/4A Convert from H6 and log to HS6 and 4A intake Triumph 6
jfarris TR2/3/3A 56 TR3 - Convert to Neg Ground or Leave As Is Triumph 18
Boggsy64 MGB Convert away from Z/S a real boost? MG 17
BoyRacer How to convert BN1 to later transmission Austin Healey 4
PATR8 Convert. Top help Triumph 6
RAC68 Wedge TR7 - Anyone Convert from Carbs to EFI Triumph 6
58Custom Is it easy to convert a '69 US dash to a pre-67? Spridgets 21
Go_Dogs_Go Convert Pertronix Pos Ground to Neg Ground? Spridgets 10
Jer convert from 74 rubber overiders to 73 style ? Spridgets 17
Aggudabbu convert cooper engien for spridget? Spridgets 23
S Convert to adjustable steering Austin Healey 12
M how to convert bn1 gearbox to 4 speed Austin Healey 17
T Check list to convert to front disc brakes Spridgets 9
livinginthepast Any SEA area folks need a convert. top frame-free? Spridgets 24
T TR2/3/3A Convert TR3 to negative earth or leave it be? Triumph 14
Magyar How to convert from positive to negative ground? Spridgets 10
mine Positive convert to negative ground? Triumph 15
R convert to electronic tach Triumph 3
AUSMHLY Instructions to convert to neg ground Austin Healey 5
R Hillman Super Minx Convert for sale Other British Cars 1
G Oil Filter - Paper, Felt or Convert? Austin Healey 15
G TR6 Cost to convert a TR-6 to V8? Triumph 39
Webb Sledge TR6 TR6 Tonneau + Convert Top? Triumph 2
J XJ6 SII Fuel Injection- Convert to carbs or rebuild? Jaguar 6
aeronca65t Convert.Top Cleaner? Restoration & Tools 10
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
