1500 single rail gearbox rebuild?
Scott_Hower
So I'm debating what to do with the gearbox in the Spitfire. It's out and sitting on my workbench. I drained the oil and removed the bellhousing. I'm trying to decide what I should do to service it. Front and rear seals are on the list, but what else should I inspect? It has 54k miles on it.
The oil was dirty, but not gritty. Gears all look good, no chips on anything that I can see, including the laygear. Reverse gear has one chipped tooth; maybe a 1/16 of an inch. The magnetic drain plug caught the fragment, plus some fine particles. It shifts fine, the shift forks and shaft are smooth.
Look like the rebuild kits include bearings and synchros and seals and a new layshaft.
I've never rebuilt a gearbox before, but I have rebuilt a few engines (successfully). I spoke to John Espisito at Quantum Mechanics and he suggested that so long as reverse is Ok, it might be best to just replace the bearings and seals and re-assemble it. How hard are bearings to replace? Do the layshaft too? Are the bearings pressed onto the input and output shafts?
Is the whole thing going to explode into a sea of tiny pieces when I remove the giant circlip on the front bearing? I have the Bentley manual and a good selection of tools.
Suggestions?
BRSLimited
First off, are you experiencing any problems with it? Noisy bearings, grinding gears, ect? If not then it's probably just best to put it back in and refill with the correct oil and keep driving it. If the bearings arn't making noise or feel rough when you spin them then I wouldn't change them. Make sure you measure the endfloat of the gears before you take ANYTHING apart. That said, they are not exceptionally hard to rebuild but you should have a manual handy and be sure to have a big enough bench to lay things out in the order they come apart. Some of the parts look like they can go in either direction but you will find out when you are putting the last part in that something is backwards (ask me how I know). As long as the reverse gear doesn't have a complete tooth missing I wouldn't worry too much about it. Also if you do decide to tackle this project make sure you use a new circlip that holds the gears onto the mainshaft. This clip should not be reused and I have had to redo several boxes that someone else rebuilt and didn't want to pay the dollar for a new clip.
Scott_Hower
Scott_Hower
Thank you.
I'll probably replace the seals and leave it alone. It shifts fine and doesn't make any strange noises.
The PO seems to have had an affinity for silicone sealant. The top cover and the front gasket were both covered in it. The front of the case has several holes drilled in it; these were all filled with blobs of sealer behind the gasket.
One hole in particular (directly below the selector shaft) isnt covered by the gasket or the bellhousing; is this normal? Seems like gearbox oil can slosh into the bellhousing and onto the clutch? The top cover is vented, so i'm guessing it's not a vent hole.
tdskip
Actually Scott I put random bits of silicone sealer on everything when I test drove it just to drive you crazy...
Ha. I'd just put it back and drive it.
Scott_Hower
Scott_Hower
Ha, I should have known!
You should see the engine. It's a work of art.
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
C LCB header with 1500 single carb inlet manifold Spridgets 1
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
bigjones Single HS4 on a 1500 Spridgets 25
J Spitfire Spitfire 1500, setup for single Weber carb Triumph 2
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
RobSelina Single SU HS4 swap on a 1500 Spridgets 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
