Intake for single SU
caseyjones955
Member
I aquired a pair of 1 3/4" dia barrel SU carbs. They can w/o any intake or linkage or anything else. I would like to use one of these carbs to replace the Zenith. I can see the carb mounting flange is incorrect, but it also looks as if I can add 2 holes and port out the intake throat to match the carb.... any thoughts on this? Is there already a readily available intake to mount a single SU or do I have to reinvent the wheel? THANKS. (79 Midget)
Tony
tony barnhill
Great Pumpkin - R.I.P
Don't know about the 1500 Midget but one off an MG1100/1300 will fit the other Midgets.
C
caseyjones955
Member
I saw some on ebay off older engines and it looks like they have 2 intake ports to head and the 1500 have an intake port for ea. cyl. Have I missed something?
Thanks for the fast comeback.
Platinum
You're into Triumph engine modifications here, Tony. P'raps the Spifire guys have a more thorough knowledge of what's available for the conversion.
didnt aomeone here just do this? i cant find anything in the search....it might have been an 1 1/2 carb, but i think they used the zenith manifold.
mark
Morris
Triumph forum may be a better resource. The 79 Midget shares the same engine as the Spitfire. I spend a lot of time looking around the web for manifold and carb mods for the 1500, and I have not seen a ready made manifold for putting a single HS6 on a 1500. I have a buddy here in town who told me he was going to hang a HS6 on his 1500 Midget using the stock manifold. I will see if I can raise him and see how he approached the problem.
Found it! wow did you fellas know that you cant search for "SU" in the forum search? Go figure... anyway It was Rob Selina that did it with an hs4. with photo even. How is it working Rob?
Single HS4
mark
aeronca65t
I ran an HS4 on my 1500 for a while. All I did was slot out the carb holes with a rat-tail file. Ran fine....I replaced it because I wanted a bigger single carb for racing (I have an S&S 2 inch "Shorty" now), but the HS4 would be a good choice for a street car.
There are twin carb 1500 Midget manifolds available for Candadian and European cars. These manifolds came with two HS2s (the Canadian and Euro Spits also had this setup). You occasionally see them on e-Bay.
C
caseyjones955
Member
Thanks, the link helps. I can see how it will go on. The
I still cant figure out what model the carbs actually are. What I have are AUD 4052 and 4053 but someone ingraved aud 4016 on the body of one of these. I cant find any info on any of these on the net. Any good SU sight that can help me figure out what I have here. From what Im reading an HS6 might be a bit much for this car. I really dont even know what these are. THANKS
Tony
C
caseyjones955
Member
Thanks, this helps greatly. I really appriciate the help. If anyone becomes interested in the intake/carb config or the homemade exhaust feel free to give me a msg, I should have it done in the next week.
Tony
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Intake header crossover passage..... Triumph 4
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
steveg TR6 Fixing the intake manifold Triumph 8
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Michael Oritt Intake manifold question Austin Healey 11
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
steve00136 MGB Intake manifold alignment MG 4
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
Lin Intake manifold drain pipes Austin Healey 29
R FFuel overflowing at Intake Manifold Austin Healey 10
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
P For Sale Weber carb/intake, header Spridgets Classified 2
K For Sale TR3 Intake Manifolds..... Triumph Classifieds 0
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
H BJ8 blew out intake manifold plug Austin Healey 10
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
T SOLD!! Original AH 100 LeMans intake manifolds Austin Healey Classifieds 2
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
bugedd Carb/intake question Spridgets 6
bugedd Intake Manifold Spridgets 12
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
C TR2/3/3A Intake/Exhaust Manifold Replacement Triumph 11
R Air Intake Deflector - Radiator Austin Healey 8
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
K Midget backfire at intake side... Spridgets 7
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
bugedd Weber intake manifold Spridgets 4
G TR4/4A Intake Manifold Question Triumph 6
TRMark TR4/4A Convert from H6 and log to HS6 and 4A intake Triumph 6
H Rad intake air deflector plates Austin Healey 6
S TR4/4A What attaches to the intake manifold Triumph 4
