Remanufactured brake calipers for sale
Ed_K
F.Y.I.
Our usual parts suppliers list the brake caliper assembly as N/A. I was searching for some brake pads today and ran across these; https://www.innerauto.com/store/products....y=brake_caliper
I don't need to mess with my calipers but I thought you all might want to know about the " apparent " availability of these parts. I have never done business with these folks so make your own decision.
Ed
Thanks Ed,
I tucked that addy away in my favorites.
/bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
Yeah ED ! that is a good site for a lot of things for the Healey. They have some good prices on car covers too !---Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
At that price though I'd pop out the old chrome plated pistons and replace them with SS.
R Cool Remanufactured Part for Vixen 2500 TVR 7
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
Editor_Reid Remanufactured Rover Engines Triumph 3
Editor_Reid Remanufactured Rover Engines Rover / Land Rover 2
U Remanufactured Electrical Products ? Triumph 9
H Remanufactured Shocks - 62BT7 Austin Healey 5
M Brake Servo Austin Healey 8
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 8
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
