TR2/3/3A Rebuilding a TR3A front end
karls59tr
Bronze
I'm an average DIY mechanic who is going to replace the trunnions and bushings on the front end of my "3" this Spring as it is the last thing required in my rolling restoration mechanical end of things.I've got the Haynes manual and feel fairly confident that I can handle the project. I'm going to tackle one side at a time. Anybody on this board done this and have any advice on any potential problems I may run into or general words of wisdom. I bought the TRF bushing kit off Ebay....made in India...is the quality up to par? The new Moss catalogue has Prothane Bushings for the Upper control arms that look much better than those in the kit. Would I be further ahead to include these in the rebuild rather than what's in the kit. Cheers Karl
Karl-
I did that on my TR4 last year, I think you'll have no trouble.
First basic advice - make sure you make or buy an adequate spring compressor.
I assume you will also replace the bushings on the lower arms? Those inserts do need to reamed to fit to the trunnions. Opinions will vary, but I did it myself with an inexpensive reamer and was happy with the results.
TRF trunnions: I bought them (the later 3 degree castor version) and am very happy with the quality.
TRF thrust washers on trunnions: For some reason, the ones TRF sold me were thin - I miked them and they were actually slightly thinner than the old ones. I didn't realize it until I made up the trunnion and then saw that the castle nut almost threaded too far onto the trunnion. I bought replacements from Moss, and they were thicker and worked well. It may have been a one time thing with TRF but the moral of the story is check the washer thickness first before assembly.
I stayed with stock rubber bushings for now but will watch how they last - I don't think they are too hard to change out later if needed.
Good luck!
Randy
I won't put anything from India on my car because of quality control issues - maybe it's just me but when I received thrust washers from India, I sent them back. Some parts good, some not so.
I have Prothane red on my TR3 upper arms and the quality is second to none. Make sure to get their poly grease for assembly. It's sticky as snot but made for poly bushings.
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Tinkerman TR2/3/3A Rebuilding Side Curtains TR3A Post 60000 Triumph 6
B TR2/3/3A rebuilding head on tr3a Triumph 4
rlandrum TR2/3/3A TR3A Disk Brake Rebuilding Triumph 9
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
S TR2/3/3A Rebuilding a cylinder head Triumph 30
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
