TR2/3/3A rebuilding head on tr3a
BillJoBob
Im beginning the rebuild of a TR3A engine. Right off the bat I have parts issues. The springs that go between the rockers have broken and I need new ones but cant seem to find a source for them. Any ideas or advice would be greatly appreciated.
Thanks!
Moseso
I looked too. They do appear to be hard to find. That could be a good thing. Joe Alexander sells solid (Delrin, I think) spacers to replace those. $32.00/set. They are said to work better. I don't know, but they are working just fine in my TR3.
B
BillJoBob
thanks...ill check them out!
TR3driver
Great Pumpkin - R.I.P
Another option is to send the entire rocker shaft assembly off to
Rocker Arm Specialist
19841 Hirsch Court
Anderson, CA 96007
Tel (530) 378-1075
(800)747-2767
fax (530) 378-1177
mailto:rocker@c-zone.net
https://www.rockerarms.com/index.htm
When they did mine, the charge was pretty close to what I was going to pay for just the parts required, and it came back with everything looking like new, except the pedestals and end caps (which were nicely cleaned but still showed the scars of 50+ years of service and countless R&R cycles).
B
BillJoBob
As always, you guys are the best! Thanks again!
S TR2/3/3A Rebuilding a cylinder head Triumph 30
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
H head rebuilding mods Austin Healey 15
I head rebuilding Triumph 32
I TR6 TR6 cylinder head rebuilding advice Triumph 15
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
