MGA Question... SAAB Shelby Wheel nuts for MGA
Martysh
I have just obtained a set of SAAB Shelby Wheels to put on my MGA...
Does anyone know the exact dimensions of the wheel nuts I will need, or even where I can get them online?
I got mine from one of the local aftermarket wheel places...just take your wheel & one of the lugs off the hub & they can match-up
Hi martysh,
I sent you a private message on how you can get them. They are 7/16.
Liam
57mga
take a wheel to a local tire store.
they will have them cheaper than you can get them on line, counting the UPS tax and other stuff.
Camshaft Yet another Saab Shelby wheel question[s] MG 14
JPSmit Saab Question Other Cars 15
SherpaPilot TR6 New Ammeter Install Question Triumph 5
R MGB 74 MGB Chrome bumper Grounding (Polarity) Question MG 7
D TR2/3/3A Question about bushing on the upper suspension.... Triumph 13
T TR2/3/3A Question regarding carpet installation Triumph 5
K TR2/3/3A One more coolant leak cylinder head question..... Triumph 5
Ohiobugeye cOIL qUESTION Spridgets 5
M MGB Disributor clamp question MG 2
K TR2/3/3A Cylinder head stud height question? Triumph 4
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
jehuie HS2 carburetor question… now with video! British Motor Corp 20
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
