Question about Series III XJ6 Motor in E Type?
jeep937
Got a line on an XJ6 motor that's 100% built and good. Will it work in my barn find 1970 E Type with triple SU's and not cross over? What should I look for here. What do we know about these swaps. I have til tomorrow to decide if I want it. Thought I'd throw a couple tourning cams in the head and do some light porting. Didn't want to do anything to the original motor that can't be reversed. Maybe have a nice powerful built block to beat on and keep the original engine for safe keeping. Would the pan on the later model work? Are the bolt paterns on the intakes and head and everything the same? Like will an early starter work on a newer motor? Are they pretty much all the same? What about motormounts? Same? Thanks guys
Just bought that motor and tons of parts.. Not sure what's wrong with it. Got 60K and hasn't run since atleast the mid 80's.. I just bought a brand new XJ motor that's built to drop in. I wanna hot rod it out and not be scared of blowing up the numbers matching motor..
LD-Ordie Series II gear lube question Rover / Land Rover 3
MadRiver Series 1 4.2 fan motor question Jaguar 6
E T-Series Mg t series question MG 2
Tinkerman TR2/3/3A Parts question TR3A post 60,000 series Triumph 5
Tinkerman TR2/3/3A TR 3A post 60000 series. Battery question. Triumph 4
B Series 1 E-Type fuel pump question Jaguar 2
Hap Waldrop A+ series block question British Motor Corp 14
GB1 T series question MG 2
SherpaPilot TR6 New Ammeter Install Question Triumph 5
R MGB 74 MGB Chrome bumper Grounding (Polarity) Question MG 7
D TR2/3/3A Question about bushing on the upper suspension.... Triumph 13
T TR2/3/3A Question regarding carpet installation Triumph 5
K TR2/3/3A One more coolant leak cylinder head question..... Triumph 5
Ohiobugeye cOIL qUESTION Spridgets 5
M MGB Disributor clamp question MG 2
K TR2/3/3A Cylinder head stud height question? Triumph 4
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
jehuie HS2 carburetor question… now with video! British Motor Corp 20
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
