Series 1 4.2 fan motor question
MadRiver
Bronze
Howdy gang,
It's been a while! I hope everyone has been well. We recently picked up a 1965 Series 1 4.2 coupe -- pretty early in the 4.2 run. The prior owner converted to a modern fan, and I'm in the process of removing it and going back to the original set up for concours purposes. I'm a bit unclear on what the right fan for the car would be. I know that it should be square, rather than round, but might anyone have a photo? I greatly appreciate it!
Thanks so much and Happy Holidays!
B.
MadRiver
MadRiver
Bronze
Marvin, Thanks so much for the information. I appreciate it!
Best,
B.
Deleted member 8987
If I remember right, there was a real good reason they changed.
Keep the old ones handy. You may find you will need them sooner than later.
PhilW
The motor will be like the wiper motor, without all that wiper hardware on the end - just a small shaft with a blade. They were terrible motors and replaced usually after a few years. I recently sold a few boxes of these Jag motor cores to a motor re-builder. They were mostly wipers, but the parts interchange, so he might make fan motors out of them. If you google "East Coast Jaguar", Wilmington, De., you can get contact info. The fan motors for series one and two look identical, but are different. One clockwise, the other counter-clockwise. Don't be surprised if the price seems high. The big buck Ferrari's of that time also used them.
Geo Hahn
Used square motors should be plentiful as so many have replaced them with the more powerful round motors. I'm saving mine in the steamer trunk with all the other original bits I've removed on the assumption that the 'next guy' will want them.
If originality is not being strictly adhered to and cooling is a concern, Mike Frank offers fans and aluminum radiators that are highly regarded (what I have now) -- Cool Cat
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
Bruce Bowker series 1 cooling fan Jaguar 5
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
sim A-series Engine Block Search Spridgets 2
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
S M Series Bonnet Striker Pin failures TVR 2
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
G original radio 1961 e series jaguar Jaguar 3
Y M Series indicator lens TVR 2
Q Series 1 E Type Clutch Jaguar 2
F 1965 Humber Super Snipe Series Va Other British Cars 5
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
David Townsend T-Series MG Midget TC Series Limited Edition Illustrations MG 1
J TR4/4A TR4 Series Vehicle numbers Triumph 1
