Wedge need tr7 distributor
hottvr
I'm looking for a delco distributor for my81 TR7.
The guy who had it before me took it apart and lost some pieces.
Thanks
Rick
hansen12@bellsouth.net
good luck, I was never able to find one for a spare. Napa lists the distributor, but do not stock it; it has to be special ordered and arrives whenever. Wedgeparts sells a lumenation conversion kit if you go to his web site there is a write up on the conversion; or you might search ebay.co.uk (ebay's united kingdom site). I have bought some hard to find items there.
Call Brad at Wedgeparts...he probably doesn't have a new one, but may have a used one. When my Delco coil went out last year, he was the only one that had a replacement.
PS....the coil is the same as the one on the 1985 Peugot 505...but don't know about the distributor.
Hello Hottvr,
if you can see if you can find a distributor from a Dolomite Sprint engine, it is a Lucas one and far better than that horrible Delco Remy unit originally fitted.
good luck,
Alec
not sure, but i don't believe the lucas distributor wil work on your engine. yours is a bosch fi engine. no vacuum advance, only vacuum retard. best bet is call brad.
piman - I thought the sprint used a Lucas distributor? RKC695R is the number rimmerbros lists.
Hello Izual,
exactly, and that is what I did on my son's TR7 (Not an injection one, however) after getting frustrated several times trying to set those Delco Remy points. The idea if putting the advance weights above the points made serviceing so akward.
Incidentally you don't need the very rare and expensive Sprint cap, a mini one works fine.
Alec
Hello Philman,
I don't know about the injection engine, but I understand why vacuum advance works, (allowing the car to run on low load at a weaker mixture i.e. economy) What is the reason for vacuum retard?
Alec
On a TR6, the retard functions at idle only AND when the coolant is up to temp. It's sole purpose is to pull the points plate CCW for a later (retarded) ignition condition. This is supposed to help lower engine and coolant temps (and presumably pollutant levels as well) when idling. The thermovalve in the upper rad hose ports high idle vacuum from beneath the rear carb to the retard capsule. To test retard function, disconnect & plug the vac hose to the capsule; the idle should increase.
Many have this feature disabled with no performance problems.
Rick O.
72 TR6
Hello Rick O,
thanks for that: you learn new things all the time.
My Triumph 2000 has an early fuel injected engine and it's distributor has no vacuum unit at all, pure mechanical control. Presumably as the engine runs a very low vacuum. 7 to 8 Hg at idle.
Alec
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
T Wedge TR7 engine, need help identifying part. Triumph 5
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
Got_All_4 Wedge Need opinion on TR7 value Triumph 3
G Wedge Need help with 1980 TR7 Triumph 2
T Wedge Anyone need a TR7 crankshaft or starter? Triumph 0
T Wedge I need a TR7 body shell Triumph 5
T Wedge Need a Triumph TR7 FHC for a TR8 conversion? Triumph 13
T Wedge Anyone need a TR7 original valve cover? Triumph 0
F Wedge 1980 TR7 ZS Carb rebuild advice [need some] Triumph 5
Hegg Wedge TR7 Pistons - Do you need some? Triumph 1
S Wedge Need Help Badly! - New TR7 Won't Start! Triumph 11
E Wedge I need some TR7 and TR8 Owners to sound off! Triumph 7
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
