Kent Cam
Kent 276 Cam MD duration asp 270° sca 280°
Is for a 1275.
Sorry Jack
yes, 1275 9.5 compression, fully ported head, maniflow intake, modified carbs, LCB, etc.
Thanks,
Patrick
heading back out to the garage, you guys are great!!!!!!!!!
Wonderful search engines on the web, I'm not really so smart.
Thanks, just know that I put in a piper that Vizard had recommeneded in another car and it was so good. Going out to strip and paint, thanks!!!!!
Hehe, wish I had one for a 948, about a stage 2 would be nice, some day maybe. I like the loapey sound.
The 276 is a nice cam good to about 7000 thru the gears and about 6200 to 6500 top gear. It is the required Spec-Sprite cam. Good with stock carbs( needle change needed). Would work great for the engine you discribed. About as much cam as you really want on the street. It will idle ok at about 12 to 1500 rpm. My Spec-Sprite make about 90HP to the back axle on my dyno. Your results may vary.
Jack,
"Stages" don't really mean anything to me, so listing specific statistics/parts is generally more helpful. /ubbthreads/images/graemlins/smile.gif
Understand, and I can not find my reference either.
Stage I = engine clean up, valves, head, 1 1/4 carbs etc.
Stage II = above with street cam, full ballance and lightened flywheel, etc
Stage III = full compontetion version, all the above and more.
Sorry but I can't do better from memory.
Walter74 Kent AH4 cam shaft Austin Healey 18
K Kent Cam valve lash ? Triumph 2
Editor_Reid Memorial Information Added | Kent Lambert, RIP Austin Healey 10
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
HealeyRick RIP Kent Lacy Austin Healey 6
C Ford 1500 Kent pre-crossflow mystery Other British Cars 16
C Ford 1500 Kent Pre-Cross Flow Mystery Lotus 20
aeronca65t More Kent engine info Racing 3
swift6 Ford Kent Engine to resume production... Other British Cars 19
swift6 Ford Kent Engine to resume production... Racing 5
aeronca65t No more Kent in FF? Racing 1
Dudly Kent Ohio, British Car Show ? Triumph 4
G Cigarettes shop-$ 14.95 for Marlboro,Camel,Kent!!! Triumph 10
G Cigarettes shop-$ 14.95 for Marlboro,Camel,Kent!!! MG 11
G Cigarettes shop-$ 14.95 for Marlboro,Camel,Kent!!! Austin Healey 7
Basil Kent Cams Triumph 8
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
